Why Has Holden Changed this on VF2?
Discussion in 'VF Holden Commodore (2013 - 2017)' started by BlackVXGTS, Feb 23, 2017.
  1. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    The front brake hose support brackets and brake hose attachments (refer picture) of my Gen‑F2 GTS look like the VT/VF ones. However, the rear brake hose support brackets and hose attachments are quite different (refer other two pictures) and don’t use the circular plastic/rubber washer that connects to the bracket. Does anyone know if this rear treatment is the same on all VF2 Commodores? Does anyone know why Holden would have made this change – was the previous method not secure enough?
    monstar likes this.
  2. KT11H
    KT11H Active Member
    VFII SSV Redline Ute
    I can only guess that they ran out of parts as the productions are coming to an end.
  3. crew_man
    crew_man Active Member
    VFII SV6 Reserve Edition Sportwagon
    Could it be because the GTS runs different brakes to Holden?
  4. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    I'm sure that whatever they use would have been 'engineer' approved although in reality it may not be suitable !!
  5. crew_man
    Have you worked for GMH and understand what goes into making an engineering change that is even as small as this one?
    bradles024 likes this.
  6. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Maybe it's a better design? Things change for many different reasons.
