wats the difference standard/supercharged blocks
hellbillybmx
wollongong
vs wagon
hi was just wondering if anyone new if there was any major differences between the internals of the standard ecotec block and the factory supercharged ecotecs they brought out in the vs statesmans also will the t5 ive got hooked upto the buick block bolt straight onto the supercharged ecotec block without having 2 change anything
thanks for any help guys
acarmody
Donati..Whoa Green
VX Berlina
LS1 James
Donates His Member
35
Andrews Farm, SA
VT II GEN3 V8 Wagz
Do a search using your title to see the differences, Has been covered Many times before.
As for gearbox everything will bolt on, Except you will need to get an 8 bolt flywheel from a VP -VS series 1 "Match Balanced" to the Auto flex plate from the L67.
Wombles
Cars cost too much.
I did a thread on this and found a few things.different between the 2 engines. Have a search and you will find.
hellbillybmx
wollongong
vs wagon
thanks for the help as for the flywheel tho where would be a good place 2 find the one i need are they rare or should i be able 2 pick 1 up at a wreckers for a good price?
