Water pump leak
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by RodsVs, Oct 3, 2019.
  1. RodsVs
    RodsVs New Member
    queensland
    vs commodore executive
    Hi all. My car is leaking coolant which seems to be coming from the back of the water pump. Is there a seal back there that needs replacing? If so how to get to it. Any advice will be appreciated 20191003_155256.jpg 20191003_155736.jpg
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    What engine? Can you post up a pic of it further away? I have dealt with lots of leaks on a Buick but i can't see from the pics what you have.
  3. RodsVs
    RodsVs New Member
    queensland
  4. greenacc
    greenacc Searching for the billion
    VE Berlina
    Yeah if the water pump is leaking you either need a new pump and gasket or just a gasket. Depends what is actually leaking. You are probably best to replace the whole thing and be done with it. Only cost about $40-50 bucks
    VS_Pete likes this.
  5. RodsVs
    RodsVs New Member
    queensland
    Yeah I've got a new one but my concern was that it's not leaking from where the gasket and pump go into the motor but from behind it. Or will a new pump and gasket stop that anyway?
  6. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Gee you took a fair bit off to replace the pump.
  7. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    Is it leaking from the timing cover ??
    Slowvxss likes this.
  8. RodsVs
    RodsVs New Member
    queensland
    Looks like it but I am replacing the harmonic balancer and crank angle sensor and thought I'd sort out the leak as well
    Trevor loves holden. likes this.
  9. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    It's leaking from behind the timing cover.
    RodsVs likes this.
  10. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    By those pictures it is
    RodsVs likes this.
  11. RodsVs
    RodsVs New Member
    queensland
    Looking at it you might be right. I'm guessing that's not going to be easy to change
  12. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    You are pretty much there already, by memory there is 4 sump bolts going in the bottom of the timing cover and just the outer one's.
  13. vs-lover
    vs-lover Well-Known Member
    VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
    and the harmonic balancer which is the hard part for those without the correct tooling.
  14. losh1971
    North Tas
    VR Ute V6
    Being an Eco, it's hard for me to say as it looks different to a Buick in a fair amount. But on a Buick the timing covers rarely leak. What does leak is the bolts that have access to coolant. I chased down a leak for six months and thought it was the timing cover. When all it was was the ground/earth bolt that goes through the timing cover had been disturbed and not resealed. I don't know if this bolt is just a Buick thing? So i can't say if you have one or not. But it sits to the passenger side, near the alt on a Buick and is one of the bolts for the timing cover.
  15. RodsVs
    RodsVs New Member
    queensland
    Time to head to the library and borrow good ol Gregory's car manual again
  16. losh1971
    North Tas
    VR Ute V6
    You know looking at the pic on the computer instead of my phone makes me wonder if it is just a bolt leak. Mine looked like the second photo on the first page. Mine only leaked after sitting all night. Couple of mech's said it looked like a leaking timing cover because of where the coolant sat.
  17. Trevor loves holden.
    vs commodore
  18. vs-lover
    I have to agree with Losh on this point.
    I'd pull out the bolts one by one and reseal them individually. Don't take them all out at the same time. Just do one at a time and then replace the pump. Use plenty of "Stag"/ Permatex Gasket Goo on the bolts and you may well be pleasantly surprised.
    RodsVs likes this.
  19. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    My thoughts from looking at the photos (on a 42" screen), the leak is coming from the water pump bolt holes.
    I seal all the bolts on my water pump (ecotec).
    In other words, l agree with losh1974.
    RodsVs likes this.
  20. Trevor loves holden.
    vs commodore
