Vz Ute srs light
Arryn
Campbelltown
Vz alloyanchor
Hey there
I got defected for two “questionable” rear tyres so I need a blue slip on my car the only thing I have left that stops it passing is that the srs light is on so I changed the clock spring that didn’t work I bought an obd2 scanner that didn’t connect then had someone come and use there’s they said there’s couldn’t read any faults and now I hear that I could change the airbag module in the centre console to reset the light is this most likely the case any help is appreciated I’m in desperate need
cheers
