VZ Ute Seats into a VR
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Brendo McGrath, Jul 20, 2019.
  1. Brendo McGrath
    Brendo McGrath New Member
    VR S Ute
    Hi Forum, Can VZ Ute seats fit a VR? We would like to go Leather SS seats. Not sure what’s required? Any feed back would be great. Cheers. Brendo
  2. Aussie Trev
    Aussie Trev Active Member
    Queensland
    2 by VX Acclaim Wagon Series II 2001 & 2002
    They may not be legal if they do fit since the SRS airbags wouldn't work in a VR would they?
  3. RWD4ever
    RWD4ever Member
    Gosnells
    VS3 ute
    VZ utes did not have side air bag. They were option on the Crewman.
    And VT-VZ seats do not fit earlier Commodores.
  4. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Doubt it would matter, as long as the ones that were factory fitted to the car work. Usually transplant seats being a problem centres around the rail or seat not being ADR compliant.
    They can be modified to fit (says VT/VX but fairly sure VY/VZ will be exactly the same) - https://forums.justcommodores.com.au/threads/vt-vx-retrofit-guide-for-vn-vp-vr-vs.59801/
  5. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    Slug powered VZ, a VE Calais & your mum.
    I had VZ seats in my old VP ute.
    I used the VZ seat back onto the VP seat base.
    Swapped the VZ foam onto the VP seat base.
