Vz Ute blinker issues
Arryn
Campbelltown
Vz alloyanchor
Hey all
move got a 2005 vz Ute for a while my drivers side blinker would stick on when unlocking/locking the doors the hazards worked fine and the passengers side blinker would still blink when the drivers was stuck on same with the hazards then all of a sudden the lights stopped all together I replaced the fuse for the hazard and blinkers but they blew out instantly twice now with the new fuses the blinkers make no sound don’t flash the hazards however don’t blink and they do make sound I’m going to replace the flasher relay but if that doesn’t work I’m up ship creek just wondering if this will fix the problem or not or if it’s going to be the pain in the ass bcm piece to fix the problem
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
You have the right idea.
Chances are you need to do a repair to the BCM.
There is a guide posted here somewhere.
krusing
Melbourne Bayside 3193
Correct as above -
You have to replace the indicator relay in the BCM,
there is also a YouTube about it.
