Vz ruff start up
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Ben Crouch, Jan 25, 2020.
  1. Ben Crouch
    Ben Crouch New Member
    NSW
    VZ Acclaim Wagon
    So the vz has been struggling to kick over the last couple days, only takes one key turn but struggles and sounds a bit ****, after the first turn over and running for a bit it kicks over better but still feels a bit off, had the battery tested today its 100%, no codes thrown, any ideas?
  2. ant797
    ant797 Active Member
    bunbury
    vy s
    Is it accelerating ok if not i would sujest throttle position sensor if it is ok then i would sujest cleaning mass airflow sensor before you do that check spark plugs and that leads are all secure on them i had a loose lead the other day nearly went out baught set of coil packs
  3. Ben Crouch
    NSW
    VZ Acclaim Wagon
    i think its accelerating ok, maf was cleaned not long ago, sparks and coils done not long ago, except i only did 5 coils cause i only had 5, will check leads
