Vz crewman wont start after fuel filter changed
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Scott Wagner, Apr 10, 2017.
  1. Scott Wagner
    Scott Wagner New Member
    Campbelltown
    Vz 3.6 crewmen
    Hi guys
    I have a vz 3.6 crewman i 1st changed fuel filter as i didnt have time tge week before when i done the service so filter changed put back together and wont start so i though maybe caz i i started it and moved it back a bit and turned it off it maybe flooded as i have see post about the flooding issues with alloytec tryed every thing i could think off and read online and still no go so though maybe pump as it didnt look like it had much pressure so changed pump and still the same so maybe fuel regulator so changed that still the same changed fuses and relays and nope still wont start have someone wind car over while i spay start ya barsted down its throat and she starts then dies keep spaying think if i keep it runing for a minute or 2 she mite keep going on her own but nope not my luck anyone have any i dears could do with the help cheers
  2. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    filter the right way around some have a check valve so cant flow backwards..?
  3. Scott Wagner
    Campbelltown
    Vz 3.6 crewmen
    Didnt think put in backwards as i can get fuel to pump out of tank but dosent seem like its got enough pressure still been trying to find a diagram on it just to make shore ive put all back in rite but not much luck finding 1
  4. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Arrow shows the flow direction Usually the crimped seam is towards the head of the arrow, so you want that to be the outlet.
  5. Trayner
    Crewman/one tonner fuel filters are a one piece unit with the fuel pump inside the fuel tank
    Tonner Matt likes this.
  6. Tonner Matt
    Tonner Matt Well-Known Member
    Darwin
    VZ 1 Tonner LS1 M6
    Ha Ha you beat me to it Trayner :) Was just gonna post this.
    Did the new fuel filter come with a couple of new O'rings.
    These O'rings need to be replaced after dismantling the fuel pump module to replace the filter.
    If you accidentally pinch the O'rings when re assembling the fuel pump module assembly, you can have issues with the fuel pressure.
    Trayner likes this.
  7. Scott Wagner
    Campbelltown
    Vz 3.6 crewmen
    That maybe the problem will give it a check tomorrow and let yous know thank heaps
    Public transport killing me lol
  8. Sabbath'
    Whoops, my bad.
    Will likely be an O-Ring issue then as Tonner Matt said.
    LexVy1tonne and Trayner like this.
  9. Scott Wagner
    Campbelltown
    Vz 3.6 crewmen
    Well checked o rings there all place corectly back to square one
  10. Nathan Zanker
    Nathan Zanker New Member
    3.6 holden crewman ute
    have a 3.8 v6 crewman ute just changed internal fuel pump filter it wont start could crank it over it may start and run seems like a fuel issue read other posts on here o ring issue maybe i get it but what about secondary pickup attached to fuel pump assy anyone explain that to me please stupid fuel tank design and with room under alloy tray you think they could put more fuel capacity in it
    plz any help would muchly appreciated bugger wont run properly let alone stay running most of the time
  11. Nathan Zanker
  12. Nathan Zanker
    diagrams of completed ones would be muchly appreciated
  13. Fu Manchu
    Fu Manchu Well-Known Member
    WA.
    Slug powered VZ, a VE Calais & your mum.
    I might have a diagram of the fuel tank set up, no diagram of the pump though.
    For the record and for anyone finding this thread relating to Crewman fuel filter or pump, here's a good How To on Youtube.
    I like this guy's videos. Good on ya Tom.
    Not a crewman, but for those at home, what the pump roughy looks like. I did cringe a few times watching him get the pump back in, but all good.
    Carl Barron's brother showing the dodgy fuel sender and which brand of pump to choose when replacing.
    Hey OP, how long did it take you to do this job? (Other than it needing to be redone?)
  14. Flying Kiwi
    Flying Kiwi New Member
    New Zealand
    VZ Crewman Cross 6
    Hi Scott
    If you haven't found the problem, but also reference for future searchers. If purchased the fuel filter only (from SCA or Repco), you would have been supplied 10mm O'Rings - DO NOT USE THEM. Purchase and replace the o'ring between the fuel pump and fuel filter with a 3/8 x 3/32
    Fu Manchu likes this.
  15. Flying Kiwi
    New Zealand
    VZ Crewman Cross 6
    I also installed an access hatch in the tray (under the tub liner) of my VZ Crewman. If anyone wants diagrams and dimensions on that, go to photos on the facebook group: Holden Crewman Enthusiasts NZ (Will also put info up about it on our Crewman website, link to that is on top of FB group). Is a you tube I did on changing Crewman Fuel Filter
  16. Flying Kiwi
    New Zealand
    VZ Crewman Cross 6
  17. Flying Kiwi
    New Zealand
    VZ Crewman Cross 6
    I also installed an access panel into my Crewman deck. Info on that is on our FB group, will put up on our website too. Links under that you tube
