VZ alloytec (how do i change spark plugs)
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by swift85, Mar 22, 2009.
  1. ashbox
    ashbox back in black
    The Car
    something black
    never said i did, but i've pulled the inlet manifold off my old vz and that was my experience so, i'd appreciate the idiot comment being removed...
    cheers
  2. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    The inlet manifold is a 2 piece, seperated by a paper gasket.
    Not removing the bolts I mentioned allows the whole manifold to be removed without seperation. Those 2 bolts only hold the two parts together, not hold the manifold to the block.
  3. soop
    soop Banned
    Smithton, Tasmania.
    2003 SS Commodore Series II
    No. You made a dumb comment based on doing something wrong. Idiot suits.
  4. ashbox
    The Car
    something black
    how is following a set of instructions, doing something wrong...?
  5. soop
    soop Banned
    Smithton, Tasmania.
    Because the instructions were wrong. Holden tech just said so.
  6. RiCeY
    Australia
    lol you can do it either way but my way saves gaskets
  7. soop
    soop Banned
    Smithton, Tasmania.
    Seems to be less work too...
    Why pull it right to bits for no good reason.
  8. RiCeY
    Australia
    Instructions also tell you to completely remove the manifold which isnt neccessary you can just lift it out the way to get the plugs out, saves removing fuel lines etc..
  9. soop
    soop Banned
    Smithton, Tasmania.
    Which by the sounds of it avoids having to depressurise the lines, which is another root around you don't have to do.
  10. RiCeY
    Australia
    I usually depressurize by releasing the line and spraying fuel into my open pores and eyes.
  11. soop
    soop Banned
    Smithton, Tasmania.
    Hahahahahahaha.
  12. Brenah
    Brenah New Member
    Manly, NSW
    VZ Exec Wagon
    Hay RiCey,
    When you lift the manifold up in 1 piece to get to the plugs, is there any other gasket or something there.
    Wanna save $150 and do it myself.
    Brendan
  13. RiCeY
    Australia
    There is but Ive never had to replace it.
  14. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Hammer or block of wood ftw!
  15. Brenah
    Brenah New Member
    Manly, NSW
    VZ Exec Wagon
    Sweet.
  16. sirjolly18
    sirjolly18 New Member
    Bathurst
    2004 holden VZ v6 ute.
  17. dorteerts
    dorteerts New Member
    Thornton NSW
    VZ Cross 6 Crewman
    Ricey's way
    Ricey,
    I did it your way. Easy, quick and no unnecessary expense for gaskets.
    Thanks for that.
    The old plugs looked fine but I can certainly notice an improvement with the new ones. Hopefully fuel consumption will also improve. I don't know how old the original ones were.
    Thanks again
  18. gunder
    gunder New Member
    Ve commodore Berlina sports
    the comment about the front and rear bolts was perfect thank you, undo all the other bolts, there is a short one on the front and back. the manifold them lifts off enough. thanks guys
  19. mike123
    mike123 Member
    perth wa
    VZ Adventra V6
    what would be the problem if you broke the gasket? Did spark plugs on mine about 5 months ago, just gave it a go and it worked, undid all bolts and lifted manifold up enough to remove and replace plugs, seems fine, no noise or anything.
  20. RiCeY
    Australia
    Vacuum leak, if your car behaves normally then the gasket is fine.
