VZ alloytec (how do i change spark plugs)
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by swift85, Mar 22, 2009.
  1. swift85
    swift85 New Member
    VZ EXECUTIVE 3.6 WAGON
    I am wanting to change plugs on my VZ alloytec,my question is how do i get to them and how do i replace them.is it a hard job?
  2. ashbox
    ashbox back in black
    The Car
    something black
    its a manifold off job
  3. PaulSV6
    PaulSV6 CHE Tuned 156.8rwkw
    Castle Hill
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    As mentioned u have to take off the Manifold,
    There are 5 bolts ontop, undo them, then disconnect all hoses it will take abit of effort to get off.
    When u take it off put a rag covering each of the 6 intake holes to stop dirt entering. All you have to do now is disconnect each of the coil packs to access the plugs.
  4. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    Might pay to obtain (buy) a replacement gasket for the 'manifold cover' in case you damage to old one before you do the job.
  5. swift85
    swift85 New Member
    Are the manifold bolts need to be done up with a tension wrench.
    And is the job able to be done by someone with a bit of mech knowledge or do you need to be a qualified mechanic.
    How do you get the plugs out (do you unclip the electrical harness and undo the one bolt to free the terminal from the plug?)
  6. danny1987
    danny1987 New Member
    vs commodore sedan
    when do u chage them on the sv6 my book says 2 different times one page says 90 one says 120 which one is it???
  7. IPCOlsenVZ
    IPCOlsenVZ Member
    05 VZ Commodore Equipe
    What are you referring to? tension?
    Tension: 16-20Nm for the plugs.
  8. swift85
    swift85 New Member
    Tension the bolts for manifold
  9. IPCOlsenVZ
    IPCOlsenVZ Member
    Of what I can see, it should be 23Nm.
  10. danny1987
    vs commodore sedan
    how many ks???
  11. IPCOlsenVZ
    IPCOlsenVZ Member
    **** I totally miss read your post and went off at a tangent:whistling. I had a look through my owners manual (which covers the stock and the 190 model) and I could only find 120km interval. Flip a coin I guess.
  12. VZCalZone
    VZCalZone now choppin the VZ
    vz calais, vx2 exec
    I'm lifting the manifold but don't want to do damage. I've taken out 5 bolts and disconnected 3 hoses, one at the intake and 1 on each side halfway along. I've got the front loose but something seems to be holding it at the back. Lifting harder is probably the way to go but wanted to check. Its a 190 not that it should matter. any quick advice would be appreciated
    ps how the hell do you get the plugs out after undoing them, they're a mile deep
  13. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    there is a bolt at the very end of the manifold only a short one, look over the back near the map sensor and you should see it, its next to it, have you also disconnected the lead to the variable intake actuator?
  14. mitch_893
    mitch_893 New Member
    Holden
    I know this post is very old, but your doing it all wrong. To save time, and the paper gasket in between the 2 halves of the manifold, you leave in the passenger side front bolt, and the drivers side rear bolt(very back of motor). These 2 bolts don't go all the way through, they are only into the bottom half of te manifold. This means u can then just chock up the front of the manifold with a block and then proceed the plug change. You should never have to replace the gaskets when doing plugs on a vz. Ve's are a different story tho, as there is less room.
  15. ashbox
    The Car
    something black
    care to elaborate on this?
    if your lifting the manifold chances are the paper gaskets will break therefore, you've gotta replace them
  16. coasty
    coasty the voices told me to
    kanwal nsw
    vz equipe & vt berlina both v6
    sounds too much like hard work. think ill drop mine into the mechanics and go fishing.
  17. FstStig
    FstStig Diagnostician
    Central Coast, NSW
    2010 VE SV6
    If you wanna pay me, I'll come and do them :p Only a Stones throw away from Kanwal :)
  18. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    The manifold is a 2 piece item, if you do not undo the front right and rear left bolts the manifold does not seperate therefore the paper gasket doesnt get damaged.
  19. ashbox
    The Car
    something black
    the inlet manifold is a once peice....
    and if you dont undo all the bolts...how are you suppose to lift it? you'd still not get any movement
  20. RiCeY
    Australia
    Yes youd know more than someone that works on these engines every day, idiot.
    mrfixit likes this.
