Vz acclaim aircon issue
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Josh howlett, Mar 2, 2019.
  1. Josh howlett
    Josh howlett New Member
    Wollongong
    2004 holden acclaim
    Hi guys im having an issue with the aircon its only coming out foot well vents and demister window vent. When i change aircon vent position you can hear the vacum noise when turning selector. I also checked the vacum line in engine bay that comes in through the firewall its still connected. Anyone have any ideas as to what the problem maybe.
  2. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    Either the control vacuum manifold behind the dials. Vacuum tubes fit into the back of it.
    Most likely, the vacuum actuator which an easy thing to sort.
    Remove the side trim from the drivers side centre console.
    It's a white plastic unit mounted right behind there.
  3. Josh howlett
    Wollongong
    2004 holden acclaim
    Could it be that. Even though i can hear the vacuum when i turnnthe dials
