VY S2 Clubsport Deadlocked Key Battery Dead
Discussion in 'VY Holden Commodore (2002 - 2004)' started by samlicastro94, Dec 17, 2019.
  1. samlicastro94
    samlicastro94 Member
    perth
    VY S2 Clubsport R8
    Hey Guy's,
    As title suggests my VY S2 Clubsport's battery in the key is dead and the car is dead locked. The car's battery isn't dead however I cannot get into the car.
    Have tried turning the key right hard even while lifting the handle and it's a no go as the key started to bend. Have also tried turning it hard left and no go on that either.
    I have called HSV and they've basically said to get a mobile locksmith to come out as they can cut a key but not program it and I'll need to get into the car to program it.
    Anyone have any suggestions or am I screwed?
  2. ant797
    ant797 Active Member
    bunbury
    vy s
    If you dont mind damaging the door seal you can wedge the door ajar a bit with big screw driver then push a bit of wire with a hook on it through at top corner try and hook the lock
  3. ant797
    bunbury
    vy s
    Could also try earthing your key and hooking it up with a wire too a 12volt supply might not be holding charge but if you give it a feed and press button while hooked up it might work heres how to open bonnet from outside
  4. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
  5. Whiteshark68
    Whiteshark68 Member
    Queensland
    VY Berlina Series II
    You do realize that the car is dead bolted and as such you can not use the interior locks to unlock the car not even if you are inside the car.
    i would go with Trevor loves holdens' idea because even if you wreck the key shell you may be able to wedge the battery in there to get enough power to unlock the car.
    Trevor loves holden. likes this.
  6. ant797
    bunbury
    vy s
    Did some reading on the termology dead locked aparently that means the door locks fucked and not even a working key fob will unlock it only way is to smash a window to get in if it unlocks with a working remote then it will unlock with the door button....yeah replacing the battery is best idea but if you note the time he posted it i doubt there would be any jaycar open
  7. Trevor loves holden.
    vs commodore
    You can buy new shells from auto stores but cheaper on ebay. Or just glue your old one up they do come apart with some effort.
  8. Trevor loves holden.
    vs commodore
    If the car is dead locked then you need the key fob to unlock it, you can do the dukes of hazard thru the window if you like. The snip wont open on any door if its dead locked.
  9. Whiteshark68
    Whiteshark68 Member
    Queensland
    Even if you smash a window you still can not unlock any of the door locks this was a security feature which made cars harder to just smash a window and unlock the car and steal it the only way to unlock the car is with a working key fob there is nothing wrong with the doorlocks. i know all about the deadbolt feature as i use it all the time in my car every time i park it at a shopping centre
  10. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    You just have to crank the key to the right i think it is and lift the handle. It takes a lot of force but will open.
  11. ant797
    bunbury
    vy s
    Theres no way this is a security feature so dangerous
  12. lowandslow
    NSW
    V2 III Monaro
    Yes. It is.
  13. samlicastro94
    perth
    VY S2 Clubsport R8
    Sorted. Ended up getting another key cut and coded however you need to get into the car for the buttons to start working after being put in the ignition. Despite the dash all having lights and security light flashing I decided to jack the car up, hook up jumper leads to my other car and still wouldn’t unlock with the buttons. Weirdly when I put the key in the lock and turned it with the jumper cables on it unlocked straight away manually....
    Lex likes this.
  14. Whiteshark68
    Whiteshark68 Member
    Queensland
    Good that you sorted it all out ;)
    Lex likes this.
