VX Head gaskets replacement
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Rob1968, Nov 11, 2015.
  1. Rob1968
    Rob1968 New Member
    Sunshine Coast QLD
    VXii 3.8 Supercharged
    Hey people. I have a VX Supercharged L67. Just wondering if i need to replace head bolts whilst replacing head gaskets? Thanku for any advice.
  2. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    Yes, they are TTY (Torque To Yield).
    Probably be an idea to replace the rocker bolts as well.
    Better to be safe than sorry, could get away with reusing them on a n/a engine but i wouldn't risk it with fi.
  3. Rob1968
    Rob1968 New Member
    Sunshine Coast QLD
    Cool thanks eh. I bought new ones for $52
  4. Colloin
    Colloin New Member
    Darwin
    VX
    Cast iron head and block. So not a huge amount of irregular expansion/ contraction. As long as the threads are clean as a whistle - I'd reuse them. They don't lose their elasticity.
  5. aussieakito
    Melbourne, Victoria
    Its always good practice to replace head bolts, im not saying your motor will fail if you dont... but for the sake of $50 or so you may as well do a job properly.
  6. billythakid
    billythakid New Member
    wello point
    vx II Executive
    Re using TTY bolts is like pissing in the wind , can be done but makes a mess
    The bolt actually elongates permantly when torqued and as soon as they are loosened they are fatigued , re using them is not worth it
