vx commodore wont start after accident
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by jasonvx1, Sep 4, 2014.
  1. jasonvx1
    jasonvx1 New Member
    sydney
    VX Equipe S2
    i was driving my car when it was raining and the car started sliding from side to side then hit a tree. The car did not crank i had to get it towed the driver said it might be a safety cut of valve (inertia switch) that needed to be reset
    can anyone help
  2. BlackoutSteve
    BlackoutSteve Member
    WH Caprice LS1
    Read your manual and it will say that if the air bags and/or seat belt tensioners are ever activated, the vehicle will not start as it's then considered unsafe.
    If those weren't triggered, then perhaps it still measures and excessive G-force and does the same.
    Contact someone with a Tech2. If it can be reset as opposed to replaced, I'd say that's the only way. :)
    I'd like to know too.
  3. dirty hands
    dirty hands Active Member
    ipswich qld
    magna
    you did what ..hit a tree ....and you expect to drive it .. what sort of tree ?
    any pictures of the car ?
  4. jasonvx1
    jasonvx1 New Member
    sydney
    VX Equipe S2
    the damage is minor
  5. jasonvx1
    jasonvx1 New Member
    sydney
    VX Equipe S2
    the air bags did not deploy
    the fuel pump primes but it wont start
  6. Wombles
    Wombles Cars cost too much.
    Got a pic of the car?
    Kinda interested to find out this answer to.
  7. jasonvx1
    jasonvx1 New Member
    sydney
    VX Equipe S2
    i will upload tommorow
  8. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Sounds obvious, but is the car still in Drive? Needs to be in Park or Neutral.
  9. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    depending on the impact may have jarred relay loose or battery may have moved
    either way after any accident the car will require a competent inspection to make sure it is still safe to drive
  10. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    The SRS module (once it deploys the airbags) sends a signal to the BCM that tells the BCM not to allow the vehicle to start. The SRS modules are once only use and cannot be reset with tech2 etc once airbags have fired.. Not too sure if you would need to reset the BCM after the airbags have been deployed of if it just resets itself once a new SRS module had been fitted and programmed to the vehicle. If the airbags didn't deploy, then maybe just the seatbelt pretensioners fired, which might also stop the vehicle from being started and driven as theyre also are part of the SRS.
