[General] VT-VZ Cabin filter mod.
scaredyet
40
Mosman
Holden VZ Lumina Wagon
Does anyone have updated pics on how to remove and fit the filter?
gr33nbastad
46
VF2 SSV Redline -- VX2 Calais LS1 A4
If I can get one to fit I will - just pulled everything apart to clean it today
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
Might do this. Have everything off for cleaning and painting.
To remove the scrivets, you'll need a trim tool and even hold the outter part and unscrew firmly but not enough to push it back it. I use the trim tool to get under them to give some pressure. Once the screw part is out a slight bit, I use the trim tool to lever the screw out.
Some I just reefed off with side cutters. I'll put a different type in that are easier to remove.
Fu Manchu
WA.
Trying to figure out what year the filter needs to be.
"Citroen grand Picasso C4 van"
Fu Manchu
WA.
Major Bump. The links are dead in OPs post.
I used the RCA174MS (Trade price $30 - Retail $85 - the box contains 2 filters). You may be better off with HEPA filters off ebay that you can cut and shove in the void behind the mesh screen.
It fits in without modification however there's a 1cm gap on both sides, so it's not quite spot on.
Those plastic scrivets are Satan however, and I could only get them out via drilling the center and using a self tapping screw & pliers.
Also just wanted to say cheers for the help
Found this on Spares Box. Thakns for the part number @TheApothecary.
Ryco Cabin Air Pollen Filter Microshield RCA174MS
$31.98 (eBay price from them)
Fits Navara '05/'06 & Pathfinder.
265mm x 100mm x 24mm
$37 +postage from their website!
https://www.sparesbox.com.au/part/ryco-cabin-air-filter-microshield-rca174ms
Could use some hot glued foam either side to snug the fit a bit.
Fu Manchu
WA.
@scaredyet
This might help some of you get into the mesh under the wiper cowl.
Also might help if you plan on getting into the HVAC for a few reasons
