DeathSammich
21
Hobart, Tasmania
VT Berlina S1
My VT series 1 is using 15L per 100KM and i dont know why. Ive changed 02 sensors, fuel pump, oil filter, fuel filter and the oil. What esle could cause bad fuel usage? it has 280xxxKms.
wortus
Have you checked the actual engine to see how much compression it has? Take out the spark plugs and see what colour they are, its a good sign of mixture. Black or brown on the porcelain could indicate it is running rich. Is your MAF sensor also clean?
DeathSammich
21
Hobart, Tasmania
VT Berlina S1
Haven't done compression test but when changed the spark plugs some were more black some were light brown
