vt manual window to electric conversion
dth2exs
adelaide
vt wagon searies 1
can it be done as i dont have the loom allready there
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2017 Captiva.
What loom? If you mean door looms with wires for power windows, they usually aren't there and need to be upgraded.
The plug for the switch block should be there under the console.
Being a wagon with rear wipers, the BCM will be the right level for power windows.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Hi
I noticed you have a vt s1 wagon.
My s1 wagon had no wiring at all. I had to install everything. Including relays wiring to them, under console, door looms.
My advice would be go somewhere, where you can disassemble everything you need, & take photos of plugs. Make sure the wire colours are noticeable in photos (for future reference), especially where which coloured wires go into which BCM plugs & relays.
Door looms must be s1, because s2 door loom plugs are different.
If you pull it all out yourself, will make a lot easier to put back into your car.
I hope this helps.
Lex
dth2exs
adelaide
vt wagon searies 1
yeah series 1 awsome i dont have to changer the bcm
dth2exs
adelaide
vt wagon searies 1
what about installing cruise control and abs
