VT heater fan squeak - how to refurb?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by ashtonwright, Mar 7, 2015.
  1. ashtonwright
    ashtonwright Member
    VT Commodore Executive
    Hi all,
    Got a pain in the bum heater fan squeak which is driving me nuts.
    I've had it out and tried to blow the carbon out of the motor, thought that would have solved it... But sadly not.
    I didn't fully take the motor apart, just the rear cover, I suspect it's the bearings at the top end.
    Any tips for taking it apart and cleaning the motor!?
    Any photos would be awesome also.
    Thanks in advance.
    Ash
  2. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    Like any motor, sounds like the thing has run dry and needs regreasing
    Hmmm
    Never tried
    As a kid, did some with some electric motors, which just had a squirt of machine oil added to it internals to help lube
    If blower fan internals can be taken apart, then possible to do, unsure how. Bearings should be accessible unless they are a sealed unit then will need something like a dry lubricant
    Maybe spray Nulon Ezi-Glide
    Is a dry spray lubricant
    Normal silicon sprays and wd40 etc may only last few days
    Try that first.
    Or
    http://pages.ebay.com/link/?nav=item.view&id=310752259165
  3. ashtonwright
    ashtonwright Member
    Thanks mate, much appreciated.
    Will do. Spray lube here I come !
  4. amg
    amg New Member
    Holden
    I only pulled the base off mine because I couldn't be bothered with fiddling with the commutator contacts and having springs popping out everywhere (it may not be like this as I never tried).
    Mine had scale and corrosion on the case, I cleaned it off and blew the inside clean and stuck a dab of graphite grease on the brass bearing at the bottom. I guess if it's worn out and making a noise you should get a new motor as they look like cheapo construction anyway.
  5. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    I've had an extensive look through the Factory Service Manual and I
    can't find anything on servicing the Blower Fan.
    It may not even be a serviceable item in regards to bearings and such and by the time you take it to an auto electrician,
    it'll probably cost you more than buying a new one.
    As said above......If it's making weird noises, chuck it and get another one.
  6. WHCapriceHBD
    WHCapriceHBD Member
    Aus
    01 VX
    Is it an easy thing to remove and inspect?
    I have never looked into it but I assumed the whole dash needed to be dropped out in order to get at the blower fan?
  7. mpower
    mpower Well-Known Member
  8. Nut Kracker
    Echuca Vic.
    VT SS 304ci (195i)
    It's quite easy and you don't have to remove the glove box as described above.
  9. mattathm
    mattathm Member
    NZ
    VT SS
    Go to a wrecker and get another one. simple. your one is stuffed.
  10. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    Throw away society mindset, stuffed and repairable are 2 different things.
    Stuffed would be the motor seized and burnt all the enamel off the wiring and no longer functions at all.
  11. WHCapriceHBD
    WHCapriceHBD Member
    Aus
    01 VX
    Wow. Thanks for the graphic. That's really easy!
  12. Jxfwsf
    Aus
    commodore
    So it's not the first motor i've pulled apart... Is the first VT heater fan motor though. Just happened to have 1 lying around....
    Took me less than 15 minutes (would take me longer to get to a wrecker), there's a shield on the shaft at both ends to keep crap out of the bearing so a quick strip and small amount of grease should get a noisy motor quiet again.
    Worst part was getting the fan off, do it carefully as it may be brittle (damn plastic) and i used a small piece of wood as a drift to knock the shaft thru as it was stuck on quite well.
    Watch your fingers putting the guts back in, the magnets will pull it in with some force.
    You may need to find some foam to replace what's around the plug as age will have taken it's toll.
    A piece of polystyrene cut carefully with a serrated steak knife should do the trick.
  13. ashtonwright
    ashtonwright Member
    Wrecker it s guys! I tried to clean it up but still annoying! Wreckers here I come : )
    Thanks for all the help
  14. ashtonwright
    ashtonwright Member
    Ps jxw thanks for th breakdown!
