VS - VR Commodore Roof lining solutions
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Deetorious, Mar 5, 2019.
  1. Deetorious
    Deetorious New Member
    Bendigo
    Holden Vs Commodore V8 SS
    Hey all,
    So I have a black commodore VS so it gets very hot inside it!
    It has its 2nd roof lining (and cardboard/ backing board) in it as the first one sagged and the board just cooked and turned to dust.
    I'm starting to see this happening in my 2nd one now as its sagged from the heat and warped the board, its cooked so when trying to push up it starts cracking.
    The backing boards are hard to come by at all and now mine is damaged I am unsure where to go or what to do to fix this issue?
    Someone please help or refer me to someone that maybe makes custom boards that will fix this happening again like maybe fiber glass backing boards???
  2. Dj1crook
    Dj1crook New Member
    1994 VR Commodore/Lexcen, 1992 Holden Nova Hatch
    What I did with my roof lining as it was starting to sag was peel the linking off and used a dust broom to brush the foam cr@p off then get yaself a can of spray paint (whichever colour you like cheap as chips/reject shop sells them cheap enough) and give it a spray it comes up very nicely
  3. cb754
    cb754 New Member
    bisibane
    vs ute
    I used super glue and thumb tacks, a little on the tack push in...done. if you are clever , make a nice pattern, or random night star effect like mine. lol
  4. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    It's a poor design that is destined to fail. Nothing much you can do about it unless you get a custom one made. All factory ones will eventually fail when they are outside in the sun.
  5. vs-lover
    vs-lover Well-Known Member
    VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
    The moral to the story is don't leave your car out in the sun all day I guess.
    The lining itself is an easy fix while the sagging board itself..........................well that's another story. I've seen some people introduce a push stud just like the wagons use and attach that to the roof rail support span that's behind the board.
    Not the perfect plush look but any things better than a headlining sitting on your head I guess.
  6. ephect
    ephect Donating Member
    VS Acclaim V6
    If the board is sagging, the Velcro isn't attached. There is Velcro strips on the roof rails and the board. If the adhesive is letting go, glue the strips on.
