VS ute series II... the work bus
Discussion in 'VR - VS' started by Adelaidetradie86, May 15, 2016.
  1. Adelaidetradie86
    Adelaidetradie86 New Member
    VS Ute Series 2
    Thanks wozza. I read through heaps of threads on here about it. I know my ute kicks them in at just over a third. Doesn t bother me too much. Seems every car is different. The VT, VX and my other VS that i had as a teenager all behaved like my ute does currently. Never going over a third in temp. Anything reading over half kinda freaks me out.
    One day if im game ill let it heat up more and see if they turn on
  2. Adelaidetradie86
    VS Ute Series 2
    New tie rod ends and a new water pump on the way for the ute.
    I have a new belt tensioner, engine mounts and CAS sitting here aswell.
    I also got my mate a set of cresent spanners.
    Kinda a present but first time they will be used are on my Ute haha.
    Didn t drive it for over a week while it sat at my work yard. Felt good getting in it again.
    Actually looking forward to getting these new bits bolted on.
    The list my mechanic mate gave me is all checked off now. I reckon we ll find some more stuff when we get back underneath it again.
  3. afstruct
    afstruct Well-Known Member
    Warners Bay
    HSV VS Maloo , 2002 Monaro
    Yeap, older vehicles usually need a little more work but between maintenance and preventive maintenance help them drive nice and hopefully relatively trouble free make them enjoyable
  4. Adelaidetradie86
    VS Ute Series 2
    The thing i like is the parts are so cheap.
    Dont have to spend much to keep them driving A1
  5. Adelaidetradie86
    VS Ute Series 2
    So power is completly out in Adelaide. Getting to spend some quality time in the silver bullet. charging my phone and looking at dobez insane build thread
  6. Adelaidetradie86
    VS Ute Series 2
    [​IMG][/URL][/IMG]
    So had a prouctive morning so far. Swapped the strut brace off the silver bullet to the ute.
    Dont like red bits in engine bay unless the car is black. So i painted the mounts black.
    On a side note i saw this absolute shocker of a car. Wouldn t let my dog sit in it.
    [​IMG][/URL][/IMG]
  7. Adelaidetradie86
    VS Ute Series 2
    Forgot to mention. Door trim colour is darker on silver bullet. was going to swap a few bits over but now i cant. Bit annoyed but ill live
  8. Adelaidetradie86
    VS Ute Series 2
    [​IMG][/URL][/IMG]
    So was having a smoke and the misses pulled up in the silver bullet. I heard a noise coming from it that i hadn t heard before....
    Thermofan was working!!! temp didn t go over half she said. Just started working at a traffic light.
  9. afstruct
    Warners Bay
    Now that's nice to know, gives some peace of mind. I'm still liking the look of that car.
    Good to see you're got some nice weather down there now after the hammering you're been coping lately
  10. Adelaidetradie86
    VS Ute Series 2
    yeah its good. my back and front yard are in desperate need of som tlc... my weekend is gonna be flat out. the old briggs and stratton is gonna cop it
  11. afstruct
    Warners Bay
    Yeap, know that feeling. My back yard isn't too bad.,I did it before we went away and hasn't hit growth cycle yet , but front yard and garden ! and maloo needs a huge clean after trip , so there's a couple of chores for the weekend
  12. Adelaidetradie86
    VS Ute Series 2
    All the parts i have sitting in my room are getting installed this weekend.
    After that im gonna have a bash at repairing the front kit.
    Anyone got tips on repairing fibreglass for me. Would appreciate anyone that has done it before giving me some pointers.
  13. afstruct
    Warners Bay
    Needs to be clean for good bonds. If it's cracks you need to V it/ scolop it out, then lay in ever widening pieces of matting to build up thickness , if cracks go all the way through only do half thickness at a time and then turn over and repeat on other side. Same with edge damage clean back and blend in/ build up, you don't want to just have a plonked on bit on top . Use a release agent on any moulds .
    Maybe see if vtchris can give any good tips, looking at his vt wagon he did a great job on his front bar
    Make sure you don't have any air bubbles, you need to squeeze all of them out
  14. Adelaidetradie86
    VS Ute Series 2
    [​IMG][/URL][/IMG]
    Sweet cheers mate. ill hit him up for some tips.
    So found small leak in radiator. Thats out. Ill pick a new one up tomorrow. The harmonic balencer is being stubborn as ****.
    My mate had a brain fade putting breaker bar on and now power steering res is in the bin... gotta grab one of them aswell. Trip to wreckers in the morning.
    Water pump and tensioner are on... no dramas there.
    Still got engine mounts, tie rod ends and the crank angle sensor.
    Put a gates heater tap on... new radiator and the cooling system should handle everything a hot adelaide summer can throw at it.
  15. Adelaidetradie86
    VS Ute Series 2
    [​IMG][/URL][/IMG]
    All back together and the idle has improved heaps
  16. Adelaidetradie86
    VS Ute Series 2
    So just drove home from my mate toddy's house. He s a holden guy through and through. Got a mint VZ maloo R8. 3 VLs back at his farm.
    I thought my ute drove nicely when i got it about 6 months ago. The difference between then and now is huge.
    Its a completely different vehicle to drive.
    I almost cant believe my odometer when i glance down while driving.
    Huge thanks to Toddy for making my car feel like it approaching 150 thousand kms... when in reality its staring down 300 thousand
  17. Adelaidetradie86
    VS Ute Series 2
    Had a heater hose let go the other day. Only clamp we didnt replace while working on the ute. Fixed it and refilled and bleed system.
    Was about to head to the country for a funeral... Stopped at BP for ice coffee and to check tyre pressure. Thought id better check for air bubbles and bleeder valve snapped off the thermostat housing and hit the bonnet. haha
    Knew the RAA wouldnt fix it on the spot but i wanted my free tow home.
    Bloke gets out his van and says "alright... whats wrong with the old girl apart from the giant bloody airconditioner hanging of the side!!!".
    Made me laugh then i showed him what i broke... He gave me a grin and said "cant fix it... you need a new housing". I said "thats what i thought you d say."
    He then proceeded to tell me that "i wouldnt be allowed to work on it anyway as its too heavily modified". Guess they have rules and regulations but i ve never really thought that my ute was "heavily modified".
    I know the police wouldn t like seeing whats under my bonnet but for an RAA bloke to not work on it is abit rough. The engine is un-opened... its just really hard to get one side of the spark plugs out haha. The tow truck driver was a champ though. Funny guy.
    All good now though. All fixed up
    Silver bullet is still going. Radiator has developed a reasonable weep in side tank. Its pretty much served its purpose as the misses just got a mazda 3 neo pretty cheaply.
    Had to do a couple things to her car so havent had much time to do anything else on my two.
    Have an engine crane at home at the moment so i think when the silver one runs outta rego i might gut it. Pull everything that i can use as spare out of it and send the rest off to the wreckers.
    My mate said that cruise control will be easy to swap over.
    My bro in law has his eyes on the pacemakers.
    Would they suit his VT wagon? im not sure if any one has an answer i would appreciate it.
    Also for people with more knowledge then me... What would i need to do to the motor to give it a good freshen up so its in real good shape when and if i need to put it in the ute?
  18. Adelaidetradie86
    VS Ute Series 2
    Havent posted in ages but ive had the ute off the road for about a month.
    Got 2 rockford shallow tens and have started the install.
    Gotta get the amp in a couple of weeks. Ill have all the wiring and the subs back in by then.
    Also relocated the jack from behind the drivers door. Will post upsome pics
  19. Adelaidetradie86
    VS Ute Series 2
    Hey all... haven t been on on ages. Life got in the way of fixing up the ute. Got another rug rat crawling around. The silver bullet had to go as i moved house and had no where to store it. I kept the front bumper as a spare for the ute.
    Got rid of the misses little mazda and talked her into letting me buy a series 2 VY Calais V8 from an older couple. Had 185000 clock but looks and drives like a car with half that. Luckily its silver so i have a silver bullet mark 2. Goes well... super comfy and has pacemakers and a 2 1/2 in twin system. Sounds nice. Also got a set of ssv s that arent on it in the photo.
    https://www.dropbox.com/s/s5ss8k592u7ipis/20180303_091449.jpg?dl=0
  20. Adelaidetradie86
    VS Ute Series 2
    As for the Ute its been relagated to living under a car cover. Hidden but not forgotten. The stereo install went well and sounds awesome. The amp/sub combo are perfectly suited to each other. Can crank everything full noise all day with no dramas. Omly downside is i lost abit of seat adjustment. Wouldn t wanna drive it to melb ftom adelaide. Ill post pics up when i remember how.
    https://www.dropbox.com/s/h53rku7gxxgf4ib/20170313_103032.jpg?dl=0
    https://www.dropbox.com/s/ffttgh0rbunnl1a/20170311_102506.jpg?dl=0
