Vs hsv manta tps problem
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Mihai, Apr 21, 2019.
  1. Mihai
    Mihai Member
    Vs hsv manta
    Hello I have a problem with my iac it's new but when I disconnect it car runs good when I plug it in rev the car end the rev sticks a 1500 then drops back slowly if I can get a bit of help with this problem thanks
  2. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    did you replaced the part in circled in the pic, sometimes it falls out or gets stuck in old tps when replacing the tps
    Mihai likes this.
  3. Mihai
    Mihai Member
    Vs hsv manta
    No I did no mate did my new one have one on it ?
  4. Mihai
    Mihai Member
    Vs hsv manta
    Sorry mate I meant my ica is playing up coz when I disconnect it car runs good if it's connected end I give it a hard rev the rev go's up to 1500 then slow to drop back to normal if not connected its won't do it
  5. Wozza
    VR_GS commodore
    IAC? if so maybe a air leak.... do a search on here as Ive seen post re this before, just cant find em :)
    Mihai likes this.
  6. Mihai
    Mihai Member
    Vs hsv manta
    Ok mate I will thanks
  7. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    It will be programmed in the tune to add iac steps when you stab the throttle and then remove them slowly. If it seems to high before dropping back it may have the wrong size iac tip or pintle to use the proper name there's 2 sizes of hole in ecotec throttlebodies and 2 sizes of pintles if it has the wrong one it could let in too much air for the programmed number of steps and cause high rpm and slower recovery
  8. Mihai
    Mihai Member
    Vs hsv manta
    is a 304 v8
  9. Mihai
    Mihai Member
    Vs hsv manta
    When I take the plug out it runs good won't have that problem
  10. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Have you adjusted the throttle stop? Maybe that's thrown the figures out and ecu is compensating poorly
  11. Mihai
    Mihai Member
    Vs hsv manta
    No I did not mate wher is that at?
