Vs 5l clutch issues
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Lando, Aug 3, 2018.
  1. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    Hopefully someone can help. I'm completing a manual conversion in my vs club sport but for some reason the clutch will not disengage . I've checked the cable and pedal which all seems fine. But the clutch is stuck on the whole time. The clutch and thrust bearing are brand new. Any suggestions would be appreciated
  2. Smitty
    Smitty Well-Known Member
    Bayside Melbourne
    Gen-F R8 Tourer wagon, VK Clubbie race car
    checked the ball height of the lever?
  3. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    On the fork? No I haven't. Can that cause the clutch to be engaged if that's not adjusted right?
  4. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    I've had the gearbox in and out about 6 times and everytime it goes in its like that fork is jamming the thrust bearing up against the clutch plate.
  5. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Sure can.....If the bellhousing has an opening underneath, with the inspection plate off, it's an easy adjustment....The reason I say an opening at the bottom of the bellhousing is, I'm unsure of later model stuff...I have an early model commodore (VC) and it has it
  6. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    No inspection plate on this bell housing. Its a brand new heavy duty clutch so perhaps I will try adjusting the fork and go from there
  7. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    So I've just checked the fork with the cable off . there is no play in the fork. Feels like it is resting on the clutch. Is this normal or should there be some play
  8. vc commodore
    south australia
    vc commodore
    Should be some play....Adjust the clutch fork, as Smitty suggested and away you go
