VR V-8 SS
Discussion in 'VR - VS' started by Deuce, Oct 14, 2012.
  1. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Finally getting some engine data with wideband AFR overlay:
    Green line is wide band data.
    losh1971 likes this.
  2. immortality
    Sth Auck, NZ
    Looks familiar o_O
    Deuce likes this.
  3. VS 5.0
    Excuse my ignorance but does that green line tell us it is running lean ?
  4. immortality
    Sth Auck, NZ
    Yes. Lean idle. But we need to verify the WB 02 data is accurate as the PCM still has the pullup resistor on the board that quiet often is removed as it effects the input voltage from the WB O2 driver.
    VS 5.0 likes this.
  5. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Yeap, pretty sure gauge was reading 16.1:1 most of the time. So green line does look a fraction high. A good spot for idle. Should go 13:1 at W.O.T but will see what happens.
    I've read about step up resistor (1000ohms) but can adjust gauge output so might try that instead.
    VS 5.0 likes this.
  6. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    Remove the resistor follow the instructions in the 11p zip folder its easy to heat with you iron and slide it sideways off the pads there's not much else close to it to get in the way.you can't adjust around it as soon as you pop it off it should read fine
  7. Deuce
    Deuce Super Stock
    '94 VR SS V8
    In the meantime, is the error a known amount? Like always 10% up, or 1pt higher than actual?
    Unlikely, but hopeful.
  8. delcowizzid
    NZ
    в∞ѕтεכ √&
    Nah I don't think it's linear so will be different amount of error from 0-5v
  9. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Went for a short drive yesterday and it looks to consistently read 2 units higher on the laptop than the gauge itself.
    So where that log says 17, it is actually only 15:1
  10. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Thought 11p had fixed the full throttle issue.
    But went for a quick drive tonight: rolling from the lights, stomp it from around 10kph, back end lights up and gets all wiggly (closed course road of course), and at around 70kph Road speed the engine light comes on and trans goes heavy again. Previously this would happen sooner/easier, so it is better but still not fixed.
    I'm sure it is more tune related than wiring, but, time will tell.
  11. immortality
    Sth Auck, NZ
    Get a log of it happening and send it too me. Hopefully something obvious once we have the data.
  12. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Cool as, I'll try that one day soon (with afr's)
  13. afstruct
    afstruct Well-Known Member
    Warners Bay
    HSV VS Maloo , 2002 Monaro
    Deuce likes this.
  14. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    If engine lights comes on does it record any codes?
    Notice with my ute gets 'lively' if nail it anything under 70km/h but cruise at that speed then hit it falls flat then really starts moving at 80km/h...although instead of lean it runs rich enough you can smell it,chews through fuel but otherwise runs well.
    Getting aldl cable & nvram 'cos like yours datalogging is only way to work out what is going on.
  15. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Last time it was a TPS code. But I will check again and see.
  16. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Starter motor might be dead.
    Pulled it out last night. Hopefully I will have time to check operation of it later today.
  17. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Well would ya look at that:
    When all them horsepowers and killerwasps fight back!!
    On a serious note, hoping to find a dead bosch starter I can use the housing from.
  18. VS 5.0
    Old mate Newton strikes again.
  19. Deuce
    Deuce Super Stock
    '94 VR SS V8
    I am trying to remember if I had a backfire on start up earlier this year and maybe that did the damage which is only showing now.
  20. delcowizzid
    NZ
    в∞ѕтεכ √&
    I might have a chev gear reduction one in my boot you can have
