VR V-8 SS
Discussion in 'VR - VS' started by Deuce, Oct 14, 2012.
  1. EYY
    EYY Well-Known Member
    VS Statesman
    Yeah those hoses are a joke. Not easy to replace either. I used the factory routing when I put the VT booster into my VS - you shouldn't have any dramas doing the same, plus probably puts less stress where the hose joins the alloy.
    I bought a whole heap of those o2 sensor bungs from china and the plugs to go in them too. They were a only a few bucks each and so easy to weld in too. Took ages for them to arrive though. I've used more than I thought I ever would haha
  2. immortality
    Sth Auck, NZ
    Every time I look under the bonnet those AC hoses wind me up, with all the accesories off the engine the AC hose from the pump to the condenser just sticks out like a sore thumb, almost as bad as the trans cooler lines which I'm considering throwing more braided lines at...
  3. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    What is it like getting rocker cover off/on?
  4. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Oh yeah!
    Love them gold rockers
    losh1971 likes this.
  5. Deuce
    Deuce Super Stock
    '94 VR SS V8
    A bit fiddly, but no big deal.
    Shouldn't be very different after new master is fitted
  6. Deuce
    Deuce Super Stock
    '94 VR SS V8
    First mock up of bracket seems like it will fit well and pedal height seems near spot on.
    One step closer
  7. Deuce
    Deuce Super Stock
    '94 VR SS V8
    More progress:
  8. immortality
    Sth Auck, NZ
    That's come up great ;)
  9. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Ok, took a bit more work but level says its level:
    You can also see the M10 to M12 adapter for rear brakeline in this picture.
    losh1971, afstruct and VS_Pete like this.
  10. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Ok, this is just a note for myself for future reference.
    For drivers side Rocker cover to come off/on with the new big VZ booster, #7 intake rocker (the very back one) needs to be reasonable open on the valve for clearance.
    This is approx 120-150 crank degrees on the balancer.
  11. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Went for a short drive to the end of the drive way (read about 7 meters) and that brake pedal feel is AWESOME!!!
    But then checked and found the adapter fitting was weeping, so back in the garage.
    Wasn't surprised though, as asked for a M10 bubble flare to M12 bubble flare adapter, and actually got M12 universal to M10 inverted flare adapter with advise to 'just drill it'. I did drill it, but a sharp drill does not leave a smooth finish.
    So I whipped the fitting off, cut down a small dremel stone to fit and polished the sealing surface. Reassembled, bled that section of line at the ABS unit, and will try test drive again tomorrow.
    Man that pedal felt good!
    VS_Pete, losh1971 and VS 5.0 like this.
  12. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Check this morning, no leaks.
    Drove down the road and back, no leaks.
    Drove to work, no leaks.
    Worked all day, no leaks.
    Drove home, no leaks.
    I'll give that a pass mark.
    Next on the list, master cylinder front strut tower support bracket.
    losh1971, VS 5.0 and Wozza like this.
  13. VS 5.0
    Winning
    losh1971 and Deuce like this.
  14. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Hi all, forgot to update once strut tower bracket was made and fitted.
    Here you go (might remake bracket oneday, but this one seems stiff and looks okay):
    VS_Pete and losh1971 like this.
  15. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Radiator was still leaking (unmagically didn't fix it self. Even got worse tbh) so fitted a recored factory tank yesterday. This means I put the shroud back on too.
    Today I got a new 100kpa rad cap and also finally found some more clips that hold the front plastic on (I have been missing the end two for about 4+ years)
    Definately looks busy in the bay with the shroud back on.
    VS_Pete, VS 5.0 and losh1971 like this.
  16. Deuce
    Deuce Super Stock
    '94 VR SS V8
    So, as per my other thread, fuel gauge stuck on full (37ohm) when i was a bit over half tank. Pulled tank out, started to remove sender/pump, heard a noise, retested resistance, and it seams the sender was stuck up on something but then dropped down. So put tank back in (after brushing top clean of stones/dirt etc). Note to self, fit breather line whentank is down, and force it back through ruthlessly to where it goes when lifting tank back up.
    ephect and losh1971 like this.
  17. Deuce
    Deuce Super Stock
    '94 VR SS V8
    I had an 800km weekend in the car.
    It went really well! Brakes were good, temp was good. It performed well (considering it was pulling around 2000kg for almost half of that, including some wicked windies and hills too).
    Potentially more kms in a weekend than I have done in the last 12 months!
    afstruct, VS 5.0 and losh1971 like this.
  18. beaker
    beaker Member
    NZ
    VX Calais
    Crikey Deuce, you've been busy! heaps of cool mods.
    Are you bringing it out to meremere this weekend?
    Hoping so, be keen to catchup with you and Immoratility again if he's about.
  19. immortality
    Sth Auck, NZ
    Hi mate,
    Long time no hear, I hope all is well. Unfortunately I won't be about this weekend as it's my first night shift back at work in 4 months.
  20. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Wow, literally read a few back pages on this yesterday and checked when you last logged into JC (the answer was almost 2yrs ago). Glad to have you back.
    I'm currently on the GoldCoast and fly back on father's day. So unless it is delayed 2 weeks, I'm out. I'm guessing your finished in Sydney and back home again? You are welcome to visit Hamilton anytime for a catch up.
    Just picked up the 11p tune from immortality so keen to get logging with the wide band as part of the data log.
