VR V-8 SS
Discussion in 'VR - VS' started by Deuce, Oct 14, 2012.
  1. Sandman
    Sandman Challenge Accepted
    HQ VC VZ
    Looks like Mark Skaife I think.
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Jee, and I thought removing the exhaust manifold on the Buick was hard enough...... Have to have lady fingers to squeeze down the side of that engine.
  3. EYY
    EYY Well-Known Member
    VS Statesman
    I’ve often wondered about the effect of corrugated intake tubing vs smooth. You going to stick with the corrugated stuff?
  4. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Me too, I remember my tuner saying years ago that there was benefits to having it corrugated, but I can't for the life of me remember what it was.
  5. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Yeap, Skaife and James Courtney I think.
    VS 5.0 likes this.
  6. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Yeah, when the larger diameter pacemakers went in I had to support the motor and drop the steering and crossmember to fit the drivers side up from the bottom.
    And passenger side sometimes hits the floor because space is so limited though.
    losh1971 likes this.
  7. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Yeah, will keep that.
    I could always remove the front elbow for open throttle body at racetrack if it's really an issue.
  8. immortality
    Sth Auck, NZ
    May as well just take the bonnet off......
  9. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Because Roadkill
  10. immortality
    Sth Auck, NZ
    They pissed me off!
  11. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Progress continues:
    All fuel sorted (and checked for leaks - all good). Booster vac, map, heater cntrl vac sorted. Carbon canister is hooked up, pcv is on. Cruise and throttle cable sorted - bracket re-drilled.
    Temporary clutch fan delete for testing - will fit fan back on later.
    Just need a little vac line tidying and sort out engine breather for drivers rocker cover.
    Tried starting last weekend - fail. Cranks but no hint of firing.
    Adjusted timing advanced. Tried this weekend - almost. Tried while jumper leads on for max starter power - and it runs. . . . really horribly and won't idle.
    Plan from here is triple double check timing and reset to stock. I think I'm still a way off.
    Then finish off little things ready to drive again and build a new tune file.
    EYY and losh1971 like this.
  12. EYY
    VS Statesman
    Did you keep the same injectors or change those too? I would've expected it to have a decent idle haha.
    Is it possible to route that accelerator cable through the manifold runners so that it's not over the top of the manifold? I read somewhere that a VN group a throttle cable is long enough for to go around the back of the manifold neatly. Not sure on availability though.
  13. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    Does it have the adjustable iac port on the rear like there v6 one has
  14. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Yeap, swapped over super6 injectors.
    I tried a dozen different routing options for the throttle cable including as you suggest. But this is the only one without super tight bends or stretching too far.
    I might get a longer cable one day. But this wil do for now.
  15. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Correct, IAC is on the back of the manifold.
  16. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Started it this weekend. Got it going with riming light in diag mode - could only get to 0° and the lock arm on dissy hit the coolant crossover fitting.
    Moved dissy 1/8th and reset leads back one spot each, fired it up, 4°, so moved dissy a bit, Bang on - 11° base at tdc.
    I'll lock that down at some point and refit fan. Then it's just the rocker cover breather and I might replace the heater tap and done.
    Finding time is the hardest thing lately
    VS_Pete, VS 5.0 and losh1971 like this.
  17. immortality
    Sth Auck, NZ
    You really need your apprentice to pick up the slack. ....:)
    Deuce likes this.
  18. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Hahaha. Best comment ever.
    Yeah, he's usually asleep on the job, off eating, or staring around the garage not helping.
    Best apprentice ever though!!
    immortality likes this.
  19. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Completed
    ephect, VS_Pete, afstruct and 4 others like this.
  20. losh1971
    North Tas
    VR Ute V6
    Is this your drag bus?? If yes can you get rid of the clutch fan?? Might save some HP but you know doubt already know that.
