The taillights work as they should but dont get brighter when pressing brake pedal. Dont know if its going to be expensive or tricky
Step one: check bulbs (you may have blown stop on both. Unlikely though) Step 2: check switch above pedal, maybe it's sticky and not moving when pedal is depressed. Step 3: report back.
there is two different switches it depends if you have cruise control https://www.google.com/search?q=vs+...e..69i57j0.20543j0j8&sourceid=chrome&ie=UTF-8
The tail/brake light wiring assemblies are prone to developing faulty earth connections also on these cars. It causes some weird effects like the tailights actually dimming when the brakes are applied. Can be corrected by running a supplementary earth wire to the body if that's the fault.
