Vn v8 355 memcal
Discussion in 'General' started by Qdf397, Dec 23, 2019.
Tags:
  1. Qdf397
    Qdf397 Member
    Tootgarook
    Vy ute 3.8
    Hi all just finished stroking a 304 to 355 for my vn, what memcal should I use, I'm running a mild cam, big injectors, twin throttle body
  2. TheIceman
    TheIceman Member
    VY Ex-cop
    take it to a tune shop get it done properly so you dont blow it up with incorrect tune
  3. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    You could have a chat to Mace Engineering about getting a tune close to what you need. But as mentioned above it really needs to go on the dyno.
  4. Deuce
    Deuce Super Stock
    '94 VR SS V8
    What are you after? As said going to a dyno is your best bet (ace performance tuning etc)
    Or are you after a reasonable base tune memcal so you can drive to the tuner (delcowizzid should be able to help)
    Or are you keen to tune yourself with wideband, data logger etc (most of what you need can be had from delcohacking.com)
    Or lastly there are aftermarket ecu's that might be easier for you (haltec / link)
    P. S interested to hear more as my combo may be similar to yours
    losh1971 likes this.
  5. shane_3800
    shane_3800 Active Member
    places
    vr commo
    Best choice is throwing a ECU in (haltec seemed to have forgotten their roots and wont do a plug and play 750) or just be a man and go carby with a 750 street demon and torque power intake.
    Did you do the stroker? Did you add a cam? Did you leave the ports stock? If yes on the latterest you should've had a bowl job done on the heads.
  6. losh1971
    North Tas
    VR Ute V6
    You "drunk posting" again, Shane??
  7. shane_3800
    places
    vr commo
    Nope Memcal is shite. Any upgraded engine needs to be tuned on a dyno. You can dissagree i don't mind but I know I'm right.
  8. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Nothing wrong with a memcal.
    You can still dyno tune them.
    "be a man and go carby"
    Really? What a dumb thing to say.
    VS 5.0, losh1971 and VS_Pete like this.
  9. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    Carbies are awesome if your into vintage cars.
  10. immortality
    immortality No more smoky bacon :( Staff Member
    Sth Auck, NZ
    Didn't think fitting a carb would be street legal on a VN?
  11. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Exactly.
    And to suggest all of the extra expense of mani/carb/reg etc when what he has will do a great job of what is required.
  12. losh1971
    North Tas
    VR Ute V6
    Yes but Shane is right and he doesn't care what anyone else thinks.
    Personally I think he might have been smoking some green stuff with his beers last night as even i know a VN with memcal can be dyno tuned, and I'm not a mechanics arsehole.....
  13. immortality
    Sth Auck, NZ
    As with anything in life, you get what you pay for. Getting a cheap memcal from ebay hasn't ended well for more than one person.
  14. losh1971
    North Tas
    VR Ute V6
    Thankfully no one so far has suggested an eBay memcal. Although every now and then a new member doesn't like the idea of spending $180 on a decent mail order tune and especially not a custom tune for 7x that. Hopefully the OP is not looking for a cheap tune, considering the effort he has put into the engine.
  15. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    If you have all the specs of engine + parts & they're actually accurate then couple of recommended tuners should be able to get it to run decent enough to start/drive BUT don't expect it to be perfect as description posted sounds like it will probably need dyno/road tune.
    Most mail order tunes work well for stockers with limited or common mods that have been done to death repeatedly.
  16. Qdf397
    Qdf397 Member
    Tootgarook
    Vy ute 3.8
    I was thinking of some thing along the lines of a base tune, I also have a haltech interceptor for it as well, it also needs to be wired to the loom
  17. Deuce
    Deuce Super Stock
    '94 VR SS V8
    So mail order so you can run it in and drive to a performance shop. Then the performance shop wire in the haltec and dyno tune.
    Sounds like a plan.
    I've got no idea where you are from and what your nearest shop is though.
  18. TheIceman
    TheIceman Member
    VY Ex-cop
    is that all? i had a VN calais 5.0L i just stuck a cam in, shift kitted tranny, 2500 stall converter and exhaust system and ran flat 14's at around 100. didn't spend a lot on it at all.
  19. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Yeap, that's all.
    It wasn't finished at that point.
    Going again in September to see what gains have been made over 3years. Hopefully low 13's. It went mid 14s as a 304 with stock cam.
    VS_Pete and losh1971 like this.
