VH SLE Power Steering Hard Lines Trouble
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by wildwogz, Apr 29, 2017.
  1. wildwogz
    wildwogz New Member
    '83 VH SL/E, '97 VT S-Pack S1
    Hey all,
    I've recently purchased a VH SLE (factory 6cyl) that has had a 308 swap done at some stage and I'm having a bit of trouble with getting the power steering hard lines installed.
    The previous owner left the 6cyl hard lines in there before doing the engine swap and sold as unfinished project. I have a complete rack assembly from a V8 VH SLE which I'm using for parts. I have managed to disconnect the 6cyl lines and slide them out from the rack with a lot of swearing but couldnt for the life of me manage to work the V8 hard lines into place.
    Is there some trick to getting these installed, or do I have to drop the rack / remove the extractors / starter motor?
    Last 6 to V8 power steering conversion I was involved with (on a VK) we did it while the engine was out of the car which made things a whole lot easier -- wish this was the case.
    Any advice is appreciated -- Cheers
  2. Smitty
    Smitty Well-Known Member
    Bayside Melbourne
    Gen-F R8 Tourer wagon, VK Clubbie race car
    .. lift the engine
    the hard lines wind their way along and behind the sump (to the rack)
    and
    yes
    removing the RH driver side extractor will prevent lots of swearing
    VE Ex Police, Chrishdt and wildwogz like this.
  3. wildwogz
    wildwogz New Member
    Thanks mate I'll have another crack next weekend
  4. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    I've done it the other way car high up on stands,no rack or pump fitted then you sort of cork screw the lines upwards from underneath...helps if someone near battery to help eyeball & guide the lines.
    Guarantee there will be swearing,some cuts & thoughts of violence.
    *** Had no chance getting extractors out with efi heads & pacemakers basically meant fun job of rack out,starter etc
  5. sire01TMK
    sire01TMK Member
    DARWIN, NT
    84 VK SL 308
    Hi mate, any chance you still have the 6cyl hard lines?
