VF2 LS3 Ute vs Sedan 0-100, 0-400m, drags etc
Discussion in 'VF Holden Commodore (2013 - 2017)' started by VF2SSVREDLINE SUN GUN, Aug 2, 2017.
  1. VF2SSVREDLINE SUN GUN
    VF2SSVREDLINE SUN GUN New Member
    VF2 SSV REDLINE UTE AUTO
    Hey Guys,
    Wondering if anyone has any info or stories comparing the utes vs sedans for straight line acceleration?
    I have the 17' ssv redline ute and was just curious if anyone knows how they stack up against a sedan.. i assume being a bit lighter the ute would have a slight edge... glad of experiences tho!
  2. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    Same, I think. Wagon is slightly slower.
  3. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    Actually, a ute body shell is 40kgs heavier than a sedan body shell.
    woooo and panhead like this.
  4. VF2SSVREDLINE SUN GUN
    When it comes out to Tare Mass however, the Ute is lighter, as far as i can tell from research its:
    Ute: 1720 kg
    Sedan 1758 kg
    Wagon: 1822 kg
    Bugger-all in the grand scheme, just curious if anyone had dragged to compare
  5. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    Interesting, as I always thought the Ute was a little heavier.
    Holden added extra metal to the rear to stiffen them up to make up for the modern Ute’s only using a half chassis.
    I clearly remember reading that as part of the VE advertising when they were first released.
    In the scheme of things for a street car it's not much and wouldn't matter but 40kg can make a difference when you are into serious racing.
    lmoengnr likes this.
  6. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Interesting. I always thought the Uterus was a bit slower?
  7. KT11H
    KT11H Active Member
    VFII SSV Redline Ute
    Ute needs 2 bags of 20 kg cement at the back to keep the back wheels in tractions. :D. But seriously, it probably comes down to the reaction time of the drivers.
  8. lmoengnr
    Sunbury Vic.
    When I fitted the cargo rails, I got to see most of the rear end 'structure'.
    Lot different to earlier designs, definitely 'beefed up', more suited for towing.
  9. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    I would guess that ute would be negligibly slower due to less traction/less weight at back wheels...
    Towcar and monstar like this.
  10. Daniel Souza
    Daniel Souza Active Member
    Glenwood
    VF2 Wagon SSV Redline
    IMG_2164.JPG My Best time with my VF Wagon redline auto is 13.316@107
    426Cuda and monstar like this.
  11. KT11H
    KT11H Active Member
    In the latest copy of Motor magazine, Bang For Your Bucks for cars under $50K. SS manual ute came 1st. with 0-100 at 5.13 sec. and 0-400 m in 13.28 sec. at 178.02 km/hr.
    monstar and 426Cuda like this.
  12. monstar
    Peugeot 207 GTi
    Hmm... would seem the Motor driver had too much spin affecting his 60’ but delivered more HP to end with better time and speed. Else the wagon’s ~80kg weighed in to drop 5kph.
    Both good stock times, @SS Flo Rida was able to bring that a full second lower just with FBO, good tuning.
    SS Flo Rida and 426Cuda like this.
  13. SS Flo Rida
    SS Flo Rida Active Member
    Gold Coast
    VF Series II SS W375
    VF Sedans are usually quicker off the line because they get better traction than utes. I've raced many times versus a few mates with VF utes at willowbank & they seem to either tramp off the line or bog down.
  14. blackve76
    blackve76 Well-Known Member
    there
    VE SS ute 360rwkw N/A, 2016 VF2 SS M6
    I remember but in the day SV8 was slightly quicker than the SS due to weight, as above ute traction is a issue.
