VF Wiper Issues
Discussion in 'VF Holden Commodore (2013 - 2017)' started by MasterC, Jan 14, 2020.
  1. MasterC
    MasterC MasterC~VsCalais
    VE CalaisV SII
    Hi Everyone
    I was wondering if anyone has encountered my issue. I have attached a video for reference.
    I have had constant issues with my Wipers. I have tried Bosch wipers and now OEM Holden wipers and I get an issue where it appears the wipers are too long and clip eachother on the way up. The video is in slow motion to show whats happening.
    I am tempted to cut the wipers, however they are supposed to be the "Correct"size.
    The link it too a Google Photos hosted Video as i cannot upload the video.
    https://photos.app.goo.gl/F8tjstBwFuQreAjq6
    Regards
    Charbz
  2. Forg
    Forg Well-Known Member
    Regal Peackock VF SS-V Redline Wagoon
    They may not work as well if you cut them, those knobs on the end are probably having some useful effect or I doubt they'd be there.
    If those are OEM wipers, there's definitely something Funky going on. Can you try to find another VE or VF to park next to & measure the arms? The only two things I can think are possible is that one of the arms is the wrong length somehow, or that somehow you've been unlucky enough to have TWO pairs of consecutive wiper-blades made by different brands which are wrong.
    Hmm, I don't suppose that the rotating mechanism, which the wiper shaft pokes out of, has the capability of adjustment, and someone's installed it/them improperly?
  3. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    Thats bizzare. Most likely the issue with wiper arms. The blades are the standard size. Possibly some odd defect with wiper arms...
    Maybe incorrect fitted when the car was built...
  4. MasterC
    VE CalaisV SII
    The Original issue with the bosch was shudder. OEM does the above. I am thinking its the arms as well. I have a feeling the arms are twisted. I really dont want to spend another 80 dollars on new blades. However i do have another VF at my sisters with fairly new blades. I may just swap the blades and see if it does the same thing.
    Ron Burgundy likes this.
  5. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    Measure the length of both blades and post it here and someone will confirm that the blades are the right or wrong length and that question is then quickly dealt with.
    MasterC likes this.
  6. TSMAX
    TSMAX Member
    HSV CLUBSPORT R8
    The driver side blade is 26" and passenger side 15". I replaced mine a few months ago, ordered some e-bay specials which were a direct fit without any issues. I have ordered another set in the past for another car and although it guaranteed fit for the car, it didn't actually fit. Just make sure you have the above sizes and it should fit.
  7. MasterC
    VE CalaisV SII
    Do you have the link for the ones that worked?
  8. Big Red VF-SII Go-kart
    Big Red VF-SII Go-kart I love puddles.
    Geelong VIC
    VF-SII SV6 (MY017) Sportwagon
    VF SV6 wipers:
    Left 65cm, right 49cm.
    Check also your windscreen is scrupulously clean, wet a CHUX wipe and scrub with metho. The blades in your vid appear to be dragging under stress - bent arms (?) , and that would strain the motor.
    In re measurements, if the right side is only slightly longer it will interfere with the left and also come into contact with the windscreen fascia in the resting position.
  9. stooge
    stooge Well-Known Member
    wa
    VF SSV
    here is a pic of the resting position of mine
    you might need to undo the right arm and move it up one or two notches so it is above the left arm when the go to wipe.
  10. mpower
    mpower Well-Known Member
    and if you have that rain-x crap get rid of that too. you can also clay your windows for the ultimate clean.
  11. MasterC
    VE CalaisV SII
    MY ones line up next to each other. in line directly. Which sounds like a bent arm
  12. MasterC
    VE CalaisV SII
  13. stooge
    wa
    VF SSV
    Have you owned the car from new?
    If not someone may have removed the wipers and not put them back on correctly or like someone else mentioned they might not have been put on correctly at the factory.
    Fu Manchu likes this.
  14. MasterC
    VE CalaisV SII
    That would be my guess. Its under factory warranty. I will annoy holden.
  15. MasterC
    VE CalaisV SII
    These are how my ones are. I would say the larger one is off.
  16. Big Red VF-SII Go-kart
    Geelong VIC
    Is it me, or are the arms nearest the wiper blades bent down (blue photo), seemingly to exert more pressure? They definitely should not be bent, anywhere.
  17. panhead
    NSW Central Coast
    Cars
    MasterC likes this.
  18. stooge
    wa
    VF SSV
    it does look like your passenger one is sitting higher than the drivers one in your picture.
    it is probably 1 notch out on the spline and comparing it to panheads picture the passenger one looks to be the one that is out of alignment as your one seems to rest higher than his in the pictures or your front window has been changed and the black border of the window is different.
    if the window has been changed maybe the guys that changed it took them off and did not put them back on properly.
    panhead likes this.
  19. Ron Burgundy
    NSW
    VF II SS
    N
    If it's under warranty just take it to Holden....
    It's their job to figure it out...not yours
  20. Anthony121
    Anthony121 Well-Known Member
    VF SSV Redline MY17 & VF Director
    Yes
    Yes what he says to do!
