VF SII Sportwagon Sv6 Subwoofer
FATBQI
Whangarei, New Zealand
VF SII Sv6 Sportwagon
Hi all, I'm picking the question has probably already been asked many times however I cant seem to find the answers (that in itself possibly answers the question).
I'm wanting to add a sub to the boot of my sportwagon. Only a 10 inch in a small box so wont take up a lot of boots pace, though there is plenty of that! Question is, do the Sportwagons have the wiring run to the boot like the sedans but simply not used or do I need to run wiring from the door sills? Would be looking at a simple install using the high level inputs. Long term I may look at upgrading speakers etc as others look to recommend but just looking to improve sound a little at this point without removing door cards, messing with factory speaker mounts etc.
mpower
talking out my arse, i doubt there would be wiring as there'd be no amp either.
FATBQI
I guess I'm just hopeful they used the same harness/loom for all models and just blank off the wires. Dreams are free maybe.
Witto
44
VF Calsis V Sportswagon
I found the best way is to use the rear speaker for my source, then use a line level converter to the Amp.
When you amp the speakers you'll want to add a quality LOC, I used A LC4i could
be happier
FATBQI
When you amp the speakers you'll want to add a quality LOC, I used A LC4i could View attachment 210794 View attachment 210795 be happier
Looks good, tidy sub as well.. what model sub is that? Where did you put the LOC and where along the speaker wire line did you pinch into the sound?
Witto
44
Its a Kicker Slim Comprt, I used tapped into the rear speaker wires. Its still a work in progress.
Witto
44
Where about in the car did you crimp into the rears though?
Right here and the same on the Drivers side.
Left Front Signal Blue - Brown/Blue
Left Rear Signal Green - Green/Black
Right Front Signal Yellow - Yellow/Black
Right Rear Signal White - Blue Black
