VF series 2 HUD
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Pete the pommy, Jul 16, 2017.
  1. Pete the pommy
    Pete the pommy New Member
    Auckland
    Calais s2
    hi, simply my HUD isn't projecting onto the windscreen, I can see that it's working when I look into the HUD unit from above, I bough the car with it not working, and the guy I bought it off said the windscreen hasn't been replaced (which I'm told could be the reason it's not projecting). Anyone have any Ideas? Many thanks
  2. crew_man
    crew_man Active Member
    VFII SV6 Reserve Edition Sportwagon
    Have you tried adjusting the position of the HUD?
    expommy likes this.
  3. expommy
    expommy New Member
    NZ
    vf II V8
    Hi thanks for your suggestion, I can see the motor working to tilt the display (its reflecting in the windshield) and I can see the actual information when I look down into the HUD unit, but for some reason its not projecting onto the screen
  4. crew_man
    Have you adjusted the brightness level of the HUD?
    expommy likes this.
  5. expommy
    expommy New Member
    NZ
    vf II V8
    hi - thanks for taking the time to make a suggestion, appreciate it, I've tried it, for some reason its just not projecting onto the screen
  6. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Try checking the fuse. Otherwise it's off to the dealer I'd say.
  7. expommy
    expommy New Member
    NZ
    vf II V8
    hi - thanks for the suggestion. I can see down into the HUD from the screen and I can see the "0kms" and it scrolls throuhg the different settings but just doesn't "project" upwards, quite annoying :)
  8. Anthony121
    Anthony121 Well-Known Member
    VF SSV Redline MY17 & VF Director
    Its only a reflection onto the inside of the windscreen. The unit does not project so unless it is not bright enough to reflect. Can you see it at night?
    expommy likes this.
  9. expommy
    expommy New Member
    NZ
    vf II V8
    hi - yeah I can see the info when I look down from the screen into the HUD unit, there must be an issue with the mirror or something that reflects the image to the screen? taking to the dealer next week, thanks for your comment :)
  10. KT11H
    KT11H Active Member
    VFII SSV Redline Ute
    Did the previous owner replaced the windscreen with non-reflective one?
    expommy likes this.
  11. expommy
    expommy New Member
    NZ
    vf II V8
    hi - I wondered that but it has the correct screen, it says on teh screen itself that its for the HUD :)
