VE SSV P182E & P0700 ERROR CODES
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Colinalcanatara, Feb 24, 2017.
  1. Colinalcanatara
    Colinalcanatara New Member
    Holden VE SSV 09
    Does anyone have any information around the error codes mainly for p182e or p0700 and if so how to fix them as the code reader isn't giving me much?
  2. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    I replied to some unrelated thread, but p0700 is still bit generic and means the tranny is having a whinge. I've had that with traction control and also ABS.
    In other words like a warning when you push the limits, clear that in order to receive more detail.
  3. VS_Pete
  4. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    P182E Internal Mode Switch - Invalid Range
    P0700 Transmission Module Requested MIL Illumination
    These codes can set if you accelerate when the shifter is between N and D. If you clear it and it doesn't come back that's probably what happened. If it does come back then the selector lever linkage adjustment and internal mode switch circuits need to be checked.
