Ve ssv a/c won’t turn on
Discussion in 'VE Holden Commodore (2006 - 2013)' started by ebonymarie, Nov 13, 2017.
  1. ebonymarie
    ebonymarie New Member
    Ballarat
    VR Calais v6 &a VZ acclaim V6
    Hi guys,
    I have a 2009 ve ssv wagon. I bought it back in April and now the warmer weather has arrived I have noticed I can’t turn my a/c on. Whenever I press the button, it doesn’t do anything. It just says a/c off. I’ve checked the fuses and the belt and they seem fine.
    Does it just need to be regased or could there be another problem?
  2. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    most likely low gas, take to ac shop
  3. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    I run mine once a week for most of the year, all the time in summer, but probably needs service
  4. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    If it wont turn on the AC symbol it's low gas.
  5. Hsv62ltr
    Hsv62ltr New Member
    Hemmant
    2009 HSV Maloo
    Im have the same issue! Had it back and re-gassed 3 times on the second brand new compressor the HVAC System shows an error code “coil compressor failure” I don’t have deep pockets to take it back to HSV..
  6. ebonymarie
    Ballarat
    I ended up getting it regased and it worked for about 3 days. Now my problem is it’s stuck on my windscreen mode and won’t change. Drivers side blows cold air and passenger blows hot.
    Changed one of the actuators and still didn’t fix it. My only option will be to pay the $160 an hour to send it to Holden so they can fix it
    Hsv62ltr likes this.
  7. lout
    Langwarrin Victoria
    VX Executive S2
  8. ebonymarie
    Ballarat
  9. RiCeY
    Australia
    Which actuator you change
    Fu Manchu likes this.
  10. Joelene
    Joelene Member
    VE Commodore
    owning a series 1 2008 SSV since new I have had my share of aircon problems.
    These fixes might help you out.
    Symptom - Aircon stops blowing cold air after a while. Sounds like it is strangling. Can't get more air by manually operating fan control....changing to recirculate or fresh air achieves nothing.
    Resets itself after being stopped for an hour or two.
    Problem- Aircon evaporator inside dash is icing up and stopping air flow. Another symptom is you will find a lot of water under the car after it has purged itself on next start up.
    Fix - Temperature probe inside the aircon unit is in the wrong place. This has happened during manufacture by Adair. Google Adair VE Commodore for a fix.
    The basic fix is - Remove Glovebox. Locate green plugs on HV control unit. Don't touch these. Next to one is a white connector with two black wires protruding from it pushed sideways into the aircon unit next to the green plugs. This is the temperature sensor.
    Turn it 45 degrees clockwise and withdraw the sensor. Open the white connector and pull the sensor out to 35mm from the connector and reinstall. This makes the sensor go into the colder air and work properly inside the unit. Then it won't ice up.
    Symptom. Air Actuators jammed in one position. Adair has a recalibrate for these.
    Turn ignition to on but don't start.
    Set fan speed manually to 50%
    Hold rear demist button for 5 seconds.
    When you hear air actuators moving and fan speed drop release button
    Wait until actuators stop moving and fan starts again.
    Reset is complete. Actuators should be in correct positions. If not then one actuator is stuffed and needs replacing.
  11. Joelene
    Joelene Member
    VE Commodore
    In addition to the initial enquiry above of 2017.....I get caught sometimes with this.
    You can push aircon on off button all you like but if you turned the fan down to zero on your last drive and the system is in manual the aircon will not turn on no matter how many times you push the On button.
    What you need to do is wind the fan speed up from zero......then the aircon will work.
    Alternatively turn the Climate control all the way to Cold (C), then hit the Auto button. The aircon will set to 17C and start blowing.....
