VE LY7 Engine
Discussion in 'General' started by JP from the naki, Jan 17, 2020.
  1. JP from the naki
    JP from the naki New Member
    New Zealand
    VX Holden Commodore
    Would anyone know if I can still get/where to get a LY7 SV6 Crate engine or reconditioned engine?
    Or possibly even cost to get full recon and what would be needed due to a bearing putting metal shavings all thru the engine?
  2. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Can probably only get a crate motor that old through Holden now. TBH neither option is really worth it, you'd be better off looking for a lowish k second hand motor.
    There's no standard cost for an engine rebuild anywhere and could be cheaper or more expensive in New Zealand depending on labour and machining costs, but 3-5k for a rebuild with all standard parts would not be an unrealistic cost provided the crank hasn't been damaged.
