Vacuum elbow replacement
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Sikkinixx, Jan 22, 2020.
  1. Sikkinixx
    Sikkinixx Ford Traitor :(
    04 VZ Wagon
    Ok, so my wagon started idling rough and had lost most of its power. After some investigation, I found the vacuum elbow off the intake manifold was cracked. I tried taping it, but it was too far gone.
    I sourced a replacement part and put it on when it arrived in the mail. Took it for a spin......beautiful :) The next day, jumped in to go up the road, and as soon as I started it, rough idle and loss of power!?? Checked the elbow was still in place, which it was, restarted it, STILL missing. That afternoon, drove it again and it ran fine.
    If anyone could give me a clue as to what might be causing the issue to reappear, I would be extremely grateful.
  2. ant797
    ant797 Active Member
    bunbury
    vy s
    Maybe your maf got some dirt in it when you had a cracked elbow clean maf some contact cleaner
  3. Sikkinixx
    04 VZ Wagon
    Just checked the maf and the wires look pretty clean. Maybe some slight discoloration, but no gunk.
    Would disconnecting the battery perhaps reset the computer? Or is there something else I can check?
  4. ant797
    bunbury
    vy s
    Scan for codes if you havnt
  5. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    Disconnecting the battery won’t reset the computer as many believe.
  6. Sikkinixx
    04 VZ Wagon
    Yeah, think I'm gonna have to get an OBD2 scanner. I noticed when I pulled the maf sensor out, there was a gasket behind it that looked pretty ratty. Could that possibly make a difference? I can also hear like an air leak sound when it's running!? Just can't seem to locate it
  7. Sikkinixx
    04 VZ Wagon
    Didn't think so, but had to ask
  8. ant797
    bunbury
    vy s
    You know what to do then check for vacuum leaks i also noticed the pcv valve connects in a few places around the top one too elbow hose looks like it come out easy
  9. Fu Manchu
    WA
    VZ V6
    Those hoses/pipes are still available new. Not expensive and would be on par with the cost of rubber hose and adaptors.
  10. Sikkinixx
    04 VZ Wagon
    I got another elbow for $18.50 from eBay. Ordered Friday, received it Monday.
  11. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    oz car parts ,Smithfield nsw sell them new around $40. I have to get some the plactic is ****
