Urgent help with ly7 vz timing chains from mace!!!!
Discussion in 'Mace Engineering' started by Callum433, Jan 26, 2019.
  1. Callum433
    Callum433 Member
    2004 vz sv6 manual
    Thanks Michael it's has been difficult but the car is basically garaged permanently until fixed and we're hoping to buy a different car in the mean time. I'm not blaming mace at all im positive it's probably an error or missread step I have made. I'll try and call someone from your team when I get time as I work a lot during the week.
    VS_Pete likes this.
  2. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
  3. VZ SV6 REBUILD
    VZ SV6 REBUILD Member
    QLD
    VZ SV6
    Not a lot, and yet it still lasted over 300k. Up until the last couple of days it still ran smooth and idled normal, though it had been losing power for a while. The idle only got rough after I put some engine cleaner through it, WAY TOO LITTLE TOO LATE I'm afraid.
  4. gungazza
    west suburbs
  5. VZ SV6 REBUILD
    QLD
    VZ SV6
    I think the engine cleaner did more harm than good. All it did was loosen up the crap and allow to circulate and block oil passages etc, there was just too much of it to remove. Luckily it only lasted a week after the engine cleaner or I think it would have ended up with a lot more damage.
  6. gungazza
    west suburbs
    what cleaner did you use ive seen some posts about using desil fuel to clean it out first
  7. VZ SV6 REBUILD
    QLD
    VZ SV6
    It wasn't cheap, but that doesn't matter, with the volume of crap that was in the engine NO cleaner was ever gonna be able to do its job.
    As for diesel, if I had NO other option then yes I would use it. It has lubricating and cleaning properties.
  8. immortality
    Sth Auck, NZ
    Running an aggressive cleaning agent when the engine is slushed up this badly is mostly a bad idea as it will loosen up all the **** and send it into the sump resulting in a blocked oil pick up and loss of oil pressure. A better option my be to run a diesel type oil which has more detergent type additives and change it out regularly to slowly remove the built up crap.
  9. scaredyet
    scaredyet Active Member
    Mosman
    Holden VZ Lumina Wagon
    What diesel oil do you recommend and how long should it be in the vehicle? I have an 05 wagon with 297K on the clock and want to do this my next oil change
  10. immortality
    Sth Auck, NZ
    Diesel oils can be found in most grades so find one that is the same recommended grade for your engine but specified for a diesel engine.
  11. scaredyet
    Mosman
    Sweeeet
  12. VZ SV6 REBUILD
    QLD
    VZ SV6
    Lol, no amount of diesel oil was ever going to remove the build up in mine, I had no idea it was that bad. In my case the only solution is to strip it down and physically clean it.
  13. immortality
    Sth Auck, NZ
    Agreed, the diesel oil trick will help with built up sludge but not that hard burnt on crap.
  14. gungazza
    west suburbs
    if and when I do my chains I think I will give it the diesel clean first
  15. gungazza
    west suburbs
    what does mace think about this diesel clean
  16. MACE
    MACE Well-Known Member
    Late, but given the amount of sludge, I would pull the engine completely apart to do a proper clean, or replace the engine altogether.
    There is waaaay tooooo much sludge for a engine flush to handle :(
