Urgent help with ly7 vz timing chains from mace!!!!
Discussion in 'Mace Engineering' started by Callum433, Jan 26, 2019.
  1. VZ SV6 REBUILD
    VZ SV6 REBUILD Member
    QLD
    VZ SV6
    So long as you haven't "forced" it to turn it should still be fine. What was the reason for work to start with?
  2. Callum433
    Callum433 Member
    2004 vz sv6 manual
    It turned over without too much effort by hand with a ratchet with a couple springy spots that I just assumed were the valve springs. They seemed a bit hard from what I remember about springs so I'm gonna say it's probably a cooked engine :(
  3. VZ SV6 REBUILD
    QLD
    VZ SV6
    plugs in or out?
  4. Callum433
    Callum433 Member
    2004 vz sv6 manual
    Most of the plugs were still in I think at that point at best one bank was out but I know I didn't take all of them out
  5. Callum433
    Callum433 Member
    2004 vz sv6 manual
    As for doing it in the first place I got the rattle after driving it for 2 weeks after purchase. I'm only a first year and don't make enough to pay for it to be done. Saved up and bought the mace set and set out to do it at home
  6. VZ SV6 REBUILD
    QLD
    VZ SV6
    Im a single dad on centerlink, I hear ya pain. How bad was the "sludge"?
    Mine started as a rattle too, then one day it wouldnt start. I had the same plan as you but found that my chains had slipped and bent 6 inlet valves so it turned into a complete rebuild. just as well cos it was absolutely FULL of sludge. I dont know how it was still running as long as it did.
  7. VZ SV6 REBUILD
    QLD
    VZ SV6
  8. VZ SV6 REBUILD
    QLD
    VZ SV6
    A few pics of what mine looked like rocker sludge.jpg cams.jpg sludge.jpg chains.jpg broken bits.jpg inside cover.jpg
  9. immortality
    Sth Auck, NZ
    Ohh my, look at those poor cam lobes.
    Take all the plugs out. It been a bit "springy" is the compression building up in the cylinder(s) as you turn it over.
  10. Callum433
    Callum433 Member
    2004 vz sv6 manual
    Holy crap dude mine looked nothing like that I can't figure out how to send pics otherwise I would. I'll try taking all the plugs out and turning it over next time I get a weekend I guess
  11. VZ SV6 REBUILD
    QLD
    VZ SV6
    On a brighter note, bit of time and elbow grease,
    VS_Pete and immortality like this.
  12. Callum433
    Callum433 Member
    2004 vz sv6 manual
    I think I figured out the pictures thing but it just says something about to big for server to process even tho the limit is 5mb lol
  13. Callum433
    Callum433 Member
    2004 vz sv6 manual
    Vzsv6rebuild I'll email you what mine looked like when I took it apart
  14. VZ SV6 REBUILD
    QLD
    VZ SV6
    go to Cloud Convert, you convert any file to whatever you want or compress file size. thats what I did
  15. VZ SV6 REBUILD
    QLD
    VZ SV6
    cool, yours looks much cleaner than mine was (understatement of the year, lol)
  16. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Easy way to shrink photos is to email them to yourself and selct large.
  17. immortality
    Sth Auck, NZ
    Good work.
  18. Callum433
    Callum433 Member
    2004 vz sv6 manual
    I use Gmail there is no select large. Either way I showed SV6.
  19. MACE
    MACE Well-Known Member
    Hi Callum433,
    We are sorry for the trouble you are facing. Can you please supply your contact number and the best time to call, will organise a call for you, otherwise you can call us on 1300 466 223 Mon to Fri before 6 PM.
    If you have any other questions, please do not hesitate to ask.
    Kind regards,
    Michael
  20. MACE
    Hi Callum433,
    Kind regards,
    Michael
    Callum433 likes this.
