[VZ] Two Hole Mod and MCAI
35
Armidale, NSW
VX Commodore 2002 Executive v6. Ex Patrol Car
The VX Commodore has the CAI mounted bottom left of the Air box...
1. Will the MCAI fit with that there?
2. do you NEED to use an MCAI?
3. Does the MCAI have a lid? Or is it open topped?
Brenah
Manly, NSW
VZ Exec Wagon
Is it the same as you see in the 1st pic?
Im pretty sure the pic is bottom left also, so yes it will fit.
No it doesn't have a lid. It collects cold air via the grill and above the light were it use to.
Just put the Radiator shroud back on
35
Armidale, NSW
Its not the same as the first pic unfortunatly :(. they are slightly different, his comes out the front bottom left, where mine comes out very bottom left in the corner, VT - Vx style
Brenah
Manly, NSW
VZ Exec Wagon
It will definatley fit.... Its a VT Monaro Stroud.
You will have a better fit on your VX compared to my VZ
Mavericks Choice
NSW
VF2 SSV M6, VF2 LS3 Calais V, VZ 6L M6 Crewie
Certainly made a difference to my Vy. I left the second hole tube loose with rubber gasket to allow easier install & removal.
crazy2009
Calais 2005 VZ V6
I got a reduction in fuel usage to from 11.9 down to 10.2 average
VAMH26
37
Seaford
VZ Berlina
Cut in the correct place, and to the right size, you can use the connection from the snorkel to funnel through the MCAI for the 2nd hole.
Ps; You can also mould the MCAI with a heat gun instead of having to cut it all up.
ACE ADVENTRA
06 ADVENTRA V6
G'day guys,
I'm a newbie to the site so forgive me if I'm repeating a question already asked, this thread is VERY interesting for me seeing that I have a 06 Adventra and well, its bloody heavy on the fuel! Bam Bam 11 said he's got his VZ down from 12.8 to 10.2L per 100K's
has anyone else done this mod to an Adventra 190kw V6?? cause the milage on my wagon is crap! right now the computer says we are getting 14.7per 100k (fair enough, its doing the school run and stuff around the burbs) BUT out on the highway the best we can get is 12.1per 100
my wagon is 100% bog stock, I'm well and truly over the "hi-performance" stuff, just looking to improve fuel economy and if it gives a bit of extra Oomph at the same time then thats even better.
also, will the monaro cold air intake mentioned in the posts above fit the V6 adventra?
reason i ask is because what would fit a normal VZ sometimes wont fit the VZ adventa like "nudge bars" (apparently a nudge bar to suit a "normal" VZ wont fit an adventra)
