trans or tailshaft shuddering?
Discussion in 'VL Holden Commodore (1986 - 1988)' started by nuttavl, Jun 29, 2010.
  1. nuttavl
    nuttavl New Member
    adelaide
    1987 VL commodore RB30
    i bought a car off a mate, we are both tryin to fix it up, while im trying to save for other expenses on it. back it the day, its was running fine until one night he had a full car and tryed to do a burnout, but dumped it to first from neutral while reving it. and ever since that when you accelerate the car starts to shudder. im pretty sure that the trans isnt slipping. so im hoping its the tail shaft or maybe even a bent axle. im not sure. we need to find the problem before we start pulling everything apart.
    its an auto by the way, and if you drive it like a manual the shudder isnt as bad. e.g. 1,2,D
    any ideas on what it could possibly be?
    thanks.
  2. Nackerz
    Nackerz Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
  3. jatsvl
    jatsvl NEEDS MORE POWER!
    vl exec wagon
    maybe your trans mounts, have alook at the back of the trans and the cross member the trans should be about 1 1/2 inch above the crossmember.
  4. detox_nath83
    detox_nath83 Another VL Driver
    Queensland(Sunny Coast)
    VL Turbo Commo
    Neutral Dump LOL
    one way to smash ya trans, As stated above,
    if it was a bent axle it would shudder all the time(unlikely)
    centre bearing, Unis, Mounts like the boys have stated
    goodluck let us know
  5. grazm
    grazm New Member
    VL Berlina
    Check out your centre bearing between the front and rear propeller shafts. The centre bearing is encased in a rubber mounting which deteriorates over time. If the rubber casing has broken away then this may be your problem.
  6. nuttavl
    nuttavl New Member
    adelaide
    orite cheers guys, ill check it out tomorow
  7. nuttavl
    nuttavl New Member
    adelaide
    thanks so much guys, i checked it out, and the trans mounts were completely shredded. centre bearing and unis is fine.
    thanks again
