Towing 1.25T boat across the Nullabor ... aftermarket oil cooler?
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Moph, Jan 16, 2020.
  1. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Love the staffies! Particularly the dog. Reminds me of my old mate Dodge. American staffy with a heart of gold and the courage of a lion. My mate for 14 years.
  2. vywgn
    vywgn Active Member
    1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
    Factory service on trans is listed at 150,000km or if required
    Moph likes this.
  3. Daniel Souza
    Daniel Souza Active Member
    Glenwood
    VF2 Wagon SSV Redline
    I started with the cheapest of the cheapest on eBay . It worked but not very reliable. I Ended up buying the OBDlink MX which is a bit pricier but is reliable and has some extra functions like going to standby.
    I use it connected to an old Android full time.
    You just have to confirm with other members if the 3.6v6 transmission temperature is available via OBDii . Mine is the LS3 v8.
    Ussually the trans temp is around 100 c sometimes hitting 110 c on my car.
    Moph and Skylarking like this.
  4. stooge
    stooge Well-Known Member
    wa
    VF SSV
    They are pretty much all the same, most of them use the elm327 microcontroller to communicate with the obd of the vehicle.
    You can get them in wifi and bluetooth flavors for connecting to the phone/tablet.
    A $7 one on ebay can work just the same as a $60 one from a store.
    The app is the important part and most people use torque on android or dash command on ios.
    You can also get gauges that dont need a phone like a scangauge or eds and if you are really keen you can get the insight cts2.
    Moph, Skylarking and 426Cuda like this.
  5. Moph
    Moph New Member
    VF Calais V wagon
    Brilliant, thanks for the heads up. Will try a cheap one off eBay initially as I don't have a great deal of use for it other than monitoring trans temps. Can always upgrade later.
  6. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    The trans have the GM quick connects. There are -6 AN quick connect adaptors available to allow converting a quick connect fitting to allow an aftermarket cooler to be fitted.
    Moph likes this.
  7. Moph
    Moph New Member
    VF Calais V wagon
    I'll have nearby gearbox shop do the work. I got rid of my ramps when I bought the Calais as I didn't want to wrench on cars anymore. The Sierra's got enough clearance that I don't need ramps.
    BTW if you're the Fu Manchu of HomeOne lawn prep fame, we followed your advice (zeolite, bentonite, molasses, etc) for our back lawn a few years back. Bloody thing won't stop growing.
    Thanks, I guess :D
    Fu Manchu likes this.
  8. VF Redline
    VF Redline Active Member
    Newcastle
    VF SSV Redline
    Do you use anything special to display all that data, mine I can get Coolant & Intake. But I don't get Oil Pressure or Oil Temp, how do I get those?
  9. Fu Manchu
    WA
    VZ V6
    I thought about getting rid of stuff when we bought the VE Calais.
    However what brought me back to doing things myself was the consistently poor standard of work by professionals. Most repairs I have paid to have done on 4 cars has ended up being redone by me because the work was so poor.
    There’s one or two jobs that have been good and I now have a mechanic I can trust that does a great job when I am time poor.
    Still prefer to do it right myself like so many of the long time members on here.
    As for the other stuff, I gave it away for a few reasons. The biggest was the rise of Farce Book and the vitriol that is delivered about my highly trained and experienced knowledge. People saying someones neighbours uber drivers budgie said they should do it some other way and essentially don’t know anything. Fkn farce book leaked into the forum like the disease it is. Too many nasty people. Had too many jobs going at once as well. 16hr days, 7 days a week. It was hard.
    Glad you liked it.
    Once bumped into the legendary C’nut on there.
    krusing likes this.
  10. Forg
    Forg Well-Known Member
    Regal Peackock VF SS-V Redline Wagoon
    This is so very, very true ... and it’s why I cling to the guy I’m currently using for grim life.
    Also why I use him rather than a dealer, including within warranty etc, even though he’s a 45-minute drive away & the commute to work goes from half an hour to 1.75 hours each way when he works on it ...
  11. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    Get a job or move closer to your mechanic :rolleyes:. Just kidding.
  12. Forg
    He needs to be convinced to move closer to me ... more central location, more potential custom! :)
    Lex likes this.
  13. Fu Manchu
    WA
    VZ V6
    This could get weird.
  14. Daniel Souza
    Glenwood
    I downloaded the extra GM PID on Torque app.
    The transmission related PIDs need the “OBD header to use” option changed from blank to 7e2 which is the Trans ID
    VF Redline, lmoengnr and Skylarking like this.
  15. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    A Trans cooler would be a good idea,
    And probably get the Transmission service for the sake of it, because it will be working hard,
    Although, when you get the momentum up, you should be ok, its just the stop/starts, overtaking and hills you have to drag it over, and get your brakes checked, because you have to Stop the whole rig sometime.
    In other words, check and service the essentials.
    However -
    On a side note,
    I would get the Wheel Bearings and seals serviced/replaced on the trailer,
    because there's not to may Bearing places out there on the Nullarbor,
    And if it happens, It will happen out the BFN.
    https://en.wikipedia.org/wiki/Nullarbor_Plain#/media/File:Nullarbor_Plain_Road_Sign_DSC04541.jpg
    https://en.wikipedia.org/wiki/Nullarbor_Plain#/media/File:Nullarbor_Plain_Escarpment_DSC04558.JPG
  16. Fu Manchu
    WA
    VZ V6
    Film the whole trip and sell it to SBS.
    krusing likes this.
  17. krusing
    Or a remake of the "Leyland Brothers" :D
  18. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    Don’t be cheap, get a satphone and live stream :p
  19. Moph
    Moph New Member
    VF Calais V wagon
    Yep, will treat it to new bearings and tyres before heading off. Also will carry a spare set of bearings, grease and maybe even a spare hub.
    I'm thinking of converting it from leaf spring to torsion axle when I get it over here so don't want to spend much on it, but I'm also not keen on being stuck on the Nullabor. Had complete bearing failure once already with the camping trailer in Karijini National Park ... I learned my lesson then :D
