The Ultimate Tacho Thread
Discussion in 'Electrical Wiring / Questions' started by 253@7k, Jul 28, 2006.
  1. MUNTED6
    MUNTED6 Banned
    vn berlina
    that happened to me so i had a spare coil pack in my shed i changed coils and the tacho worked(revs) wen i examined both coil packs the coil that didnt work was missing pins, so may u should try changing coils
  2. UNDACOVER
    UNDACOVER New Member
    VZ
    anyone no where to hook signal wire on vz alloytec.....thanks
  3. VTPREDATOR
    VTPREDATOR New Member
    Warwick
    VE SS SPORTSWAGON
    need help for my autogage monster tacho. which wires do i cut at the back for a v6. theres a orange loop and a brown loop of wire?
    cheers,
  4. AdamAnt
    AdamAnt New Member
    VY Acclaim
    what wire do i use for a tacho in a vy v8
  5. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
  6. Nackerz
    Nackerz Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Ok in a vl i have just wired up a tacho
    on the back of the cluster there is a black plug which is the main plug for the cluster
    on that plug in one of the corners is a RED with BROWN wire that is the signal wire for the tacho so just splice into it and connect your signal wire from your monster tacho to that wire....
    there is also a negative wire on the back of the cluster so you can splice into that too....
    and get your test light and check which has power there should be only one when ignition is off
    when you turn your lights on to parkers there should be power to a ???Brown??? wire i think it is and you splice into that for your tacho light so when you turn your lights on the tacho light comes on!
  7. dan0
    dan0 New Member
    VP Calais
    my car club is in the process of building up a drag car out of a VP commodore.
    We have stripped the entire interiour out including the dash/cluster etc.
    Wanting to hook up a tacho separately and have tried every combination of wires to get it to register. Will a tacho work regardless of whether the cluster is connected up or not? Should it matter at all?
    cheers.
  8. Nackerz
    Nackerz Rollin
  9. Nackerz
    Nackerz Rollin
  10. LN3Vitara
    LN3Vitara New Member
    NZ
    3.8 V6 Vitara
    Hey guys, I have a Suzuki Vitara that my son has brought off trade me here in NZ, it has a VP 3.8 V6 in it, the guy my son brought it off hasn't tied up all the loose ends so im slowly doing it up so we can get off roading in it. The vitara dash is gone, so im setting up my own gauges in it. So far I have got fuel, temp, oil press working. I am now stuck on the tacho, I've got a wiring diagram that tells me the signal wire for it should be brown, Ive connected that and the gauge doesnt like it, must be cause it is a digital pulse as has been posted on here, so i cannot find the brown/red wire or the other one with the white connector that other people have in their factory looms. Is there an output from the ecu or anything that has the correct signal? as the ecu is easily accessible for me.
    Any help appreciated
  11. GlenM
    GlenM New Member
    Merredin
    VY SS Ute
  12. 97VTSS
    97VTSS Guest
    You all probably all know this. When I installed a tacho into my VT 304 195i SS the car would turn over but NOT start. HMMMMMM I wondered, what cold be wrong?????? After few choice words and kicking the dog (just joking), it turned out the wire I attached to the signal wire was earthing out preventing the car from starting. I asked the engineer who modified my engine if this would harm the car in any way if I put a concealed switch in the signal wire to earth to act as a security / "bloody thing wont start, forgot the switch", switch. He said it shouldn't hurt it at all. What do you think? As I would like to get a 2nd and 3rd and 4th and 5th and so on opinion.
  13. ilmanguns
    ilmanguns New Member
    Indonesia
    VH 1.9L
    If i may,
    I already understand what the colors of cable and where its connected to. But, can someones tell me,
    From the cable to tacho, i didnt know where is the negatif, plus, and coil connected on the tacho itselve.
    Can someone tell me the description on my vh factory tacho. Cheers.
    Thanks for the advance.
  14. catapolt
    catapolt New Member
    western australia
    5.0lt vt calais
    can anyone tell me what colour wire it is for a v8 l77 VE ute please i have tried all the brown wires that i can find lol
    and the ve built in tacho runs off 2 signals i belive so i cant tap into that or even the coil as it has 8 of them :S
  15. Tasmaniak
    S.E. Melbourne
    yarp...pushin' the smelly stuff up hill to install a monster tach into a VE without a tach generator added in also.
  16. catapolt
    catapolt New Member
    western australia
    5.0lt vt calais
  17. 93VpCommodore
    93VpCommodore New Member
    New South Wales
    93 VP Executive Series II 3.8L 5sp Manual
    !!!!!!!!!!!!!!Help Please!!!!!!!!!!!!!!
    Hi there im only new to the site and im trying to install my 5"Saas Tacho With led shift light to my 93vp commodore executive 5sp Manual and every where i read it says connect it to the brown wire under the bonnet on the LHS Strut tower and ive done that and nothing so i got my muti meter on it and its got power to it so i got my misses to rev it why i look at the muti meter and it goes up with the revs so then i tryed hooking it up under the dash nothing i try the coil pack way nothing (The Rest Of The Wires Are Correct)so i would really appeciate so help as i reckon some out there would of had this problem
  18. Largey
    Largey New Member
    Vk Berlina
    X2 I returned the gauge to the shop and he of course had no idea. I've got a vk v6/t5, sux not havering a tach.
  19. Largey
    Largey New Member
    Vk Berlina
    I looked into this further today, the v6 only puts out a 5v signal. All the readily available tachos these days run off a 12v signal. We need to get a converter to change it.
