t56 problems help!?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by ls1nut, Feb 6, 2017.
  1. ls1nut
    ls1nut New Member
    nsw
    2001 VX Calais LS1 Manual Factory FE2
    Hi forum i just got a T56 swapped in my old calais ls1 and it sometimes jumps out of reverse gear.
    Is it just the stock shifter being a **** or is it something more?
    Gonna try a shift kit but i'd like some advice from those of you's who have had this problem before as its pretty common but new to me.
  2. Trayner
    common problem with the t56, mine does it now and then.
  3. ls1nut
    ls1nut New Member
    nsw
    Sweet cheers did you find a Short Shifter helped?
  4. Trayner
    Not really , the only way to fix it is get someone to pull the box apart, but I found If I put it in 6th gear then select reverse it goes in easier
  5. ls1nut
    ls1nut New Member
    nsw
    yeah cheers i also heard going from 1st or 5th to R works cheers mate
  6. ls1nut
    ls1nut New Member
    nsw
    If the shifter feels a bit "loose" would that cause it? All forward gears are fine.
    im thinking short shifter time
