Supercharger rotors flaking metal
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Rob1968, Nov 13, 2015.
  1. Rob1968
    Rob1968 New Member
    Sunshine Coast QLD
    VXii 3.8 Supercharged
    Guys anyone ever seen this before?
    Ride is Supercharged 3.8 VX.
    I had an overheating issue recently due to blown head gasket. As i pulled top end down, i noticed the chrome coating on blower rotors was peeling and flaking off.
    All this coating was sucked all through the valves and chambers.
    No apparent damage to bores or heads and i havent pulled down blower yet.
    My query is... Do i have to rebuild blower with new rotors? Will they still seal efficiently without the chrome coating?
    This is my first supercharger so any advice would be great thanks folks.
  2. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    The blower will run fine without the coating on the rotors. Will make 2/5th's of f#ck all difference.
  3. Decicrate
    Decicrate Member
    BrisVagus
    VS L67
    The coating is there to take up the tolerance between the rotors. It is there to help seal the rotors so the blower pumps more air, it also helps to slow air slip which heats up the air.
