Supercharged VT
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Stevierocks, Nov 7, 2019.
  1. Stevierocks
    Stevierocks New Member
    Camira
    VT supercharged sedan
    My VT has been jerking violently on acceleration... anyone have the same issue?
  2. shane_3800
    shane_3800 Active Member
    places
    vr commo
    Could be anything lol. But it sounds like it's hesitating under high throttle load which would indicate to me possible spark plugs or coil packs at first glance. But could be other issues.
  3. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    I have similar issue when my Super6 when its cold ATM, drive great when warm ;)
    Where I do know the LIM gaskets need replacing, as I haven't done them yet, due to its not a 5 minute job,
    Also check for any vacuum leaks, that will cause the same fault,
    as I found the OEM vacuum hoses had split/perished on the plastic fittings they connected to that connected to other hoses. :mad:
    I replaced ALL the vacuum hoses and it helped, but the LIM gadgets are next.
    Also if you get a chance, lift your bonnet in a DARK area, and see if you have a Christmas Tree under there, :eek:
    that is a sure sign of Plugs and Leads, but be careful poking around under bonnet in the dark, especially with a Super6 with the pulley up high. :cool:
  4. Stevierocks
    Camira
  5. Stevierocks
    Camira
    Thanks for that Shane, I have replaced the coils & plugs, The car performs fine if I ease down on the throttle, once I get to about 20kph.. no issue, only happens if I floor it from a standing start.
  6. Stevierocks
    Camira
  7. Stevierocks
    Camira
    Hi Krusing, Those vacuum hoses are a pest... I"ve had to replace some of mine due brittleness, What are LIM gadgets? I'll try checking for sparks in the next evening.
  8. Utel67
    Utel67 Active Member
    Tasmania
    Vs s3 ute
    Check for fault codes, could be a stuffed throttle position sensor.
    krusing likes this.
  9. krusing
    LIM Gaskets
    [sorry spell check in my original message, I have edited accordingly] :rolleyes:
    Lower Intake Manifold,
    [old school name is Valley Cover Gaskets, now I am showing my age]
  10. Stevierocks
    Camira
  11. Stevierocks
    Camira
    have replaced the "valley cover gaskets" about 12 mths ago....Their a common problem with the supercharged V6.. Overheating is another problem I've had to deal with, I fixed that, lotta fun getting to that thermostat housing that Holden wisely stuck behind the engine.
  12. krusing
    Ahh the Old Thermostat at the Back of the Supercharger Trick !,
    Yes I have been their and done that, had to replace the STUCK thermostat, that almost cause the motor to cooked itself.
    I ended up pulling the rear intake off the blower, to get to the thermostat, that's the only way.
    The other thing I recently found, the Temp sender plastic where the loom plugs onto gets very brittle, and can break off, and they play havoc with the ECU,
    I found that one by mistake, ended up replacing it with an after market one, and its doesn't read as high at as the OEM one, so I went to put the original one back in and the plastic broke, so I'm going to the wreckers to get a OEM one.
    Where the Super6 ones deteriate quick because of the volume of heat at the rear of the engine,
    As the STD V6's have them at the front of intake manifold, and last a lot longer.
  13. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Have you changed the spark plug leads? If not, worth a try.
    Lex likes this.
  14. klrtim
    klrtim New Member
    Hobart Tasmania
    Commodore VT / SS L-67 Supercharged V6 3.8
    YUP my coil packs were causing my vt to stumble on acceleration up hills and when heavy foot operation. $150.00 at repco 10 mins swapping the 3 coil packs, car screams now, ps IAC valve was also dirty as hell . cleaned it and monitoring it with Advanced engine diagnostic software till new IAC arrives. hope this helps Bro let us know
  15. Stevierocks
    Camira
    Thanks for that info, I'll check the coils although I replaced the coils 18 myhs ago... Where is the IAC valve?
  16. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
  17. Stevierocks
    Camira
  18. Stevierocks
    Camira
    Found the issue... big black pipe between the air filter box & throttle body had split on the underside... wrapped the split area with racers tape... obviously the airflow into the throttle was being disturbed... Quite unbelievable how such a small thing could adversely affect the performance of the engine... very important to pass this info onto our Members
    krusing likes this.
  19. krusing
    Well done !,
    I am one that will check my Super6 out tomorrow now you have let the members know.
