Supercharged v6 Vox stalling
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by JJH08, Apr 15, 2019.
  1. JJH08
    JJH08 Member
    sydney
    06 vz ss 6.0l
    hi so this morning my vx just died in the middle of a busy intersection this is the first time this has happened now the car is randomly doing it I checked for codes but there are none would this be the cas or something different, the revs will slightly drop and then stalls but starts straight away any help would be appreciated
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Check battery terminals.
  3. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    When you checked for Codes, did you short pin 5 & 6 out,
    Or check with a scan tool/analyser.
    As some codes may not activate the engine light,
    providing the engine light globe is not blown/damaged/missing, then it wont display any fault.
  4. JJH08
    JJH08 Member
    sydney
    06 vz ss 6.0l
    Hi I checked the battery terminals and also changed the battery 2 weeks ago as for the codes I shorted the pins all I got was 12 my friend has a scan tool and all I got was the air bag resistance to low as the air bag light is on
  5. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Maybe be the dfi module or the plug....
