Seanute1sttime
- Oct 11, 2020
- 1
- 0
- 1
- Age
- 64
- Location
- South Africa
- Ssv v8
Hi guy's,,, in the series 2 SSV v8 ute there are 2 x 8" subs at the bottom by the B pillars.
Do they come off a hidden amp, and if yes, where is the amp mounted.
Someone said it's behind the rear trim panel, but the wires from the subs come forward till in line with the seat, then they go under the carpet under the seat into the center console. There is almost definitely no place in the console for the amp. So I'm wondering if the subs come off the deck, seeing as they are only 50 watts, but 2 ohm.
So basically is there a hidden amp and where, or not.
I need to find out if I can then use the sub wires to a high low convertor to run 2 amps for 2 x 10" subs and splits.
Thanks for any help guys.
