SRS air bag light
Discussion in 'Electrical Wiring / Questions' started by MicTheGreaseMonkey, Nov 14, 2019.
  1. MicTheGreaseMonkey
    MicTheGreaseMonkey Member
    2000 l67 commodore berlina
    I've got a problem the SRS indicator light doesn't turn off. I hav measured the voltage to the air bag fuse & found no voltage @ the fuse terminals in the in cabin fuse box. Im not electrically minded, so where do i go from this point? the vehicle is a vx commodore.
  2. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    It will be a plug on/under one of the Seats most likely,
    Driver and/or Passengers Seat that has dislodged, they may of been pulled apart, or fallen apart,
    Check them first.
    And if you do locate the fault, disconnected the battery for 10 minutes,
    That should extinguish the SRS MIL, however, it will place into the Error History area in the BCM/ECU.
    If not you will need a Tek2 or similar to reset it.
    In actual fact, the same tool will indicate which one is at fault, if you get it scanned, it should indicate/lead you to the right fault area.
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    I say clock spring, once the light is on you can only clear it with a scan tool. The yellow plugs beside the seats may have fell out.
    TazzI likes this.
  4. krusing
    What Area of Melbourne you in ?
  5. MicTheGreaseMonkey
    Altona
  6. krusing
    Ok, If you were close by, I would of scanned it for you,
    I am located in Black Rock/Beaumaris Area, which is a 1 hours drive.
    You would think there would be someone closer to you that maybe able to scan it for you.
  7. MicTheGreaseMonkey
    What sort of scanner u got wad looking @ em but the bloke @ repco said it would not read my commi.
  8. Trevor loves holden.
    vs commodore
    You need a tech tool or get one of those cheap ebay pc tools like tuner pro which can remove air bag light. OBD2 don't work until 2006 or on some models 2004.
  9. Trevor loves holden.
    vs commodore
  10. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
  11. Utel67
    Utel67 Active Member
    Tasmania
    Vs s3 ute
  12. Trevor loves holden.
    vs commodore
