Spark plugs smaller than origional ones
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Connor john, Sep 26, 2018.
  1. Connor john
    Connor john New Member
    Kyabram victoria
    Vt calais
    Basically the title says it all bought new spark plugs and the threads are like 10mm smaller o.o will try post a pic but dunno how. Just signed up. Frequent reader new member. Cant add it q.q. the ones in there say bosh super and the ones i bought are dual fuel ngk ones from supercheap (cheap ones)
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    So the NGK's are shorter reach? What part number is on the Bosch and what is the part number on the NGK?
  3. Connor john
    Kyabram victoria
    Vt calais
    20180926_213550.jpg cant tell u part no untill tommorow finished with it for tonight put old one back in because i didnt know if the new ones would work the same
  4. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    You need bpr6efs-15 If it's ecotec bpr6efs-13 If it's lpg or s/c
  5. EYY
    EYY Well-Known Member
    VS Statesman
    Definitely don't put those in, as delcowizzid said they're the wrong ones.
  6. Connor john
    Kyabram victoria
    Vt calais
    Are the old ones even worn? Or do they just need a clean. And yeah thanks kinda figured they were wrong hence why j didnt put them in xd. Whats s/c mean btw? Its dual fuel non factory fitted. V6 vt calais. Also how do i clean them if thats suitible? Its not hard on fuel btw its quite good. Just wanted to swap plugs. Idk why guess im stupid lolol
  7. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    s/c = supercharged
    Connor john likes this.
  8. Connor john
    Kyabram victoria
    Vt calais
    Ok thanks mate. Shoulda seen that coming lol
    accentstencil likes this.
  9. losh1971
    North Tas
    VR Ute V6
    If the car is running right the plugs should be burning clean regardless of fuel. Those plugs look ok and don't need cleaning.
  10. EYY
    VS Statesman
    definitely change the plugs - you'll damage them trying to clean them. Prevention is better than cure, especially when it comes to duel fuel.
  11. Connor john
    Kyabram victoria
    Vt calais
    Ok thanks.
  12. losh1971
    North Tas
    VR Ute V6
    If you buy new plugs get some Bosch standard platinum. I've been using them for over 10 years including dual fuel and never had an issue. Like EYY said don't clean them. A friend from up the road had a peice break off on his Prado and it meant a full rebuild as it trashed the engine. Don't know if he cleaned his plug or whether it was just a faulty plug.
  13. Rexy13
    Rexy13 New Member
    VX
    So what are thebest plugs to use for dual fuel
  14. losh1971
    North Tas
    VR Ute V6
    I have used Bosch Platinum and they are great on LPG and petrol.
  15. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    easy take them back ask them for the right ones lol
  16. NeddyBear
    NeddyBear Veteran Mountain Biker
    Queensland
    2004 Ford Falcon RTV Ute & 2004 Subaru Outback 2.5
    How'd you get the wrong ones, didn't you refer to the plug dogalogue?
  17. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    How much for the platinum plugs?
    I now run Autolite plugs, costs me about $20 for 6 plugs and they do 20,000 km before I change em out. Before that I ran those fancy iridium plugs that cost about $20 each.... Cost Vs benefit I'll take the stock type plug any day.
  18. losh1971
    North Tas
    VR Ute V6
    I normally pay around $7 each for Bosch Platinum. They are the middle range in Bosch. Mine normally last 50k but can go longer, 50 is where I choose to swap them. I was warned against Autolite. Sounds like you are having no issues with them. I rocked up at my old mech garage with Autolite and he told me to them back as he wouldn't fit them.
  19. EYY
    VS Statesman
    Standard NGK's I use tend to go around 40,000km before I change them. Don't think I've ever had spark plugs give me any issues at all actually but I only ever use NGK.
  20. losh1971
    North Tas
    VR Ute V6
    Sometimes I wonder about the hype around plugs. Seems like some mechs will only use NGK, others say Bosch and some say Champion. Then you have Immortality who has used Autolite for years and had no issues. Really got to wonder if there are any plugs that are no good???
