Serpentine belt part number
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by losh1971, Aug 13, 2017.
  1. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Having all sort of issues trying to work out what belt I need. Trying Ebay but some say fits ute then others with the same part number say doesn't fit ute. Anyone have a Gates and a Bosch part number that will fit my ute with aircond? According to what I see on eBay, the V8 one is the same as the V6 but I can't be certain, because apparently a ute is different again???? Also says that some Calais have no aircon. Absolutely confusing. Really need to order one tomorrow as I won't have any transport for a week as it is... And parts shops are just crazy on prices in Tas... Hence I want to try and buy one online.
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    IMG_1707.jpg Surely it's the same belt on ute and sedan, engines are the same aren't they?
    Supercheap website shows these for a V6 VR ute. Does your old belt still have numbers on it?
  3. losh1971
    North Tas
    VR Ute V6
    Ute is broken down two hours away so can't get numbers until I can arrange a lift and really want to get it going on the same day I get a lift. Checked the above numbers on Ebay and they don't match up with the VR belts on eBay. Might have to pay the extra and get one from Burson's or the like.
  4. crew_man
    crew_man Active Member
    VFII SV6 Reserve Edition Sportwagon
    There is a ~5mm tolerance between brands, so it is likely that Dayco and Gates will have different part numbers for belts that suit the same application.
    6PK2370 - V6 w/ A/C
    6PK1650 - V6 w/o A/C
  5. losh1971
    North Tas
    VR Ute V6
    Cheers mate I now have a couple in my watch list on fleabay now. Gonna check local price before I order one online.
  6. losh1971
    North Tas
    VR Ute V6
    55 bucks locally $28 inc freight on eBay. Far out..... I might have to slip the old one on as a temp fix to get me going and then order one online. Need to try Repco but I need to call in there to get the best price.
  7. losh1971
    North Tas
    VR Ute V6
    Repi's have one for $35 gonna on hold for me. Figured if I get one online to save $7 I might end up with it not fitting and not able to return it. Hopefully now everything else will arrive by Fri and I can get a lift home to do the repairs and have transport once again.
  8. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    Yeah Gates brand is steep...other brand normal rubber usually half that or some $50 with tensioner wheels.
    Think ea falcon take same belt as air con buicks,found out the shorter belt w/out air con is least stocked when wanted to ditch air compressor.
    Bang an old belt on if it's just to get home.
  9. losh1971
    North Tas
    VR Ute V6
    Car is at home stuck in my shed. I'm staying at my GF's nearly 2hrs away. Was thinking of chucking on the old belt while I wait for one to be sent. But knowing my luck it will break on my way to work where there is no mob reception like has happened before a couple of years back... An extra 7 bucks, knowing I can swap it at Repi's if it doesn't fit seems like the better option.
  10. gtrboyy
    vt ss & lc gtr
    My belt looked nearly new so I bolted air compressor..rather wait untill it breaks & order short $20-$30 belt
    The dfi/coil pck on the other hand probably should keep in car as spares....
    losh1971 likes this.
  11. losh1971
    North Tas
    VR Ute V6
    Yeah I am hearing the DFI goes. I will add it to the list of parts I need to get but right now I have spent a lot on the ute so gonna put it down the list until the house is completed and signed off. Hopefully it keeps going in the meantime. If it goes I can get it towed to my GF's and work on it there as I keep a small kit in her shed in-case I need to fix something that can be done with a few basic tools.
